Author Topic: Help pls my friends !!!  (Read 1596 times)
uykaf
« on: July 26, 2010, 03:00:28 PM »
i bought a bis 126 last month. After i had completed the buying papers etc. i finally started my dear bis and enjoyed the driving. But  it stopped  after 2 km. i was surprised. then i started it again and it went 2 km and stopped again. after all, i couldnt start and call a mechanic. my mechanic changed the fuel pump. i have used my bis for about a month after changing the pump but the stopping happened again yesterday. now i am on the country and no service can reach here.
can you please help me my friends ???
- is the problem about the fuel pump again ????
- if so. can i mend it or can i change it with a new brand fuel pump on myself without any mechanic help ???
Re: Help pls my friends !!!
« Reply #1 on: July 26, 2010, 09:02:39 PM »
Hi uykay,
when anybody buys a second hand car the best thing to do is to service the car because you don't know how well the servicing has been done in the past. new  points, condenser, plugs, there not very expensive parts and once done you know there right, clean the filter and give it an oil change, I would be surprised if the pump was at fault if your 126 was running well when you had the pump changed, it is easy enough to check by taking the petrol pipe off the carb put the pipe into a container, then crank the engine and see if its pumping petrol. if that's O.K. you could have some dirt in the carb which may need cleaning out.
Have you a fuel filter on the petrol pipe to the pump ??? if not that is a must to stop dirt and rust getting into the carb
Most jobs on the 126 aircooled and Bis are just basic mechanics and can usually be done with the basic tool kit supplied with the car :)
« Reply #2 on: July 26, 2010, 09:16:19 PM »
Get you mechanic to change the rod that drives the pump.
This rod wears shorter and stops pushing the pump.
When the engine gets hot the casings get bigger and the rod no longer can push the pump.
