Author Topic: spot welder  (Read 1734 times)
spot welder
« on: July 26, 2010, 12:48:48 PM »
Re: spot welder
« Reply #1 on: July 26, 2010, 02:06:27 PM »
That is a mickey mouse variation on the carbon arc torch which relies upon the two faces being welded being in close proximity so that the arc can melt a hole through the near side to the outer panel and if you are lucky the metal may fuse around the hole. Unfortunately you would not know if it has been a success until the joint fails or you do a destructive test. You want a proper spot welder (resistance welding) like the one I have. The copper electrodes clamp the joint together then blast the amps through . The point of high resistence is the joint face so the steel melts then fuses in an instant. It is the way most vehicles are assembled  [-/
Re: spot welder
« Reply #2 on: July 26, 2010, 08:12:52 PM »
i suppose for the amount of money it goes for its worth a look at but like rusty said i wouldnt trust it to use on a car where the integrity of the weld could jepodise body strength.
Re: spot welder
« Reply #3 on: July 26, 2010, 09:23:42 PM »
Not done allot of welding but i have put front wings on a vauxhall by drilling 1/8 holes every 15-20mm then welding the holes up with a mig welder if that makes sense.
landyman
Re: spot welder
« Reply #4 on: July 26, 2010, 11:23:01 PM »
used something very similar in the 1980,s practice on similar metal thicknesses until you are happy with the result and don't rely on the weld for anything too structural just for cosmetic panels/sheeting but price ok for what it does
     good luck andy
Re: spot welder
« Reply #5 on: July 27, 2010, 11:20:24 AM »
Going to hire a proper job... [-/
