Author Topic: Ignition question  (Read 9091 times)
jokke
Ignition question
« on: July 22, 2010, 07:20:26 PM »
Hello!
Have one question about eletronic ignition to 126EL(X)
On the pulley it's 2+1 trigger. which is the trigger for TDC?
Is it the trigger that is to the right in the picture?
Thanks an regards from Norway. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
Re: Ignition question
« Reply #1 on: July 22, 2010, 08:57:58 PM »
Hi Jokke,
Welcome to the forum, The 126 el/elx were never imported to the U.K. But if you give it a few days maybe some of  our Polish Friends may be able to help you with the info ;)
jokke
« Reply #2 on: July 22, 2010, 09:15:39 PM »
Thanks.!
Oki, I bought complet ignition i Poland last week, but the pulley don't fit bis, so I have to modify the pulley I already got!
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #3 on: July 23, 2010, 08:20:56 PM »
I have been thinking about the same Modification [-/ but using the FIAT CINQUECENTO 700CC pulley and ECU,
A CINQ 700cc Manual would be very helpful If anyone has one ;)
jokke
« Reply #4 on: July 29, 2010, 06:59:39 PM »
I think when the piston are at TDC, the sensor sould be 10 degrees before the first trigger at the pulley. See pic:
This pic is for a cinq, but  have to mirror it, then it's is correct to the 126.
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #5 on: July 30, 2010, 07:04:04 PM »
That Looks right, so the sensor is timed @ TDC.
The worse thing that could happen is that it won't start ;)
jokke
« Reply #6 on: July 30, 2010, 07:23:51 PM »
hehe.. jepp, and I will try and see if it start, just waiting for som bits to complet the engine.
Will let you know if it works. :)
But why does Fiat use 2+1 trigger wheel? and what is happening when it reads the different triggers?
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #7 on: July 30, 2010, 07:53:35 PM »
Don't Know </* must be a reference point maybe the position of the Camshaft ???
jokke
« Reply #8 on: July 30, 2010, 09:35:14 PM »
It is a little special..
But will post when I have mounted on mine. if it start or nada.. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
ape20ff
« Reply #9 on: June 12, 2011, 06:36:22 PM »
Hello to everybody.
That's the right one for 126 engines:
The thoot for the setting of the advance at the idle is the first on the left, so jokke was right.
On later polish 126s were used 2 diffrent idle settings accordind the diffrent ignition ecus.
From 1994 to april 13 1995(engine 37077822) were used cinquecento ignition ecus(nanoplex med 210/211A) with idle at 4° BDC,then 10° BDC with nanople med 213A.
Here you can the ignition maps of 210/211(a) and 213(b).
The 3 diffrent ecus:
Look at the pulley and the sensor with its bracket on the engine:
See how to set up the ignition:
When the center of the sensor and the center of the thoot meet each other the ecu recognizes it as the advance at the idle,if it happens 10° BDC that will be the idle,x° before TDC x° at the idle.
What is important fpr the ecu is the sequence of the theet so it doesn't matter how you build your home made trigger wheel and where you put the sensor.
Some exemples:
In that case was used an adjustable flange on the pulley and fix sensor on the right.
Here a fix flange and an adjustable sensor bracket on the left:
Somebody uses to solder the 3 theet on the standard pulley too:
Do you wish an exemple of conversion on 126 bis too?
« Reply #10 on: June 13, 2011, 11:05:26 PM »
Thanks for posting this information, I'm sure it will help as there are allot of the later type engines with electronic ignition coming over to the U.K. from Poland :thumbup
ape20ff
« Reply #11 on: June 14, 2011, 02:56:39 PM »
Hello.
Not at all,Pete.
About your question about fiat cc pulley I must say:Mind!
It isn't suitable for 126s,it's from an anticlockwise engine,it hasn't got centrifugal pulley like in 126s and the crankshaft can be different.
Look at the following,the sequence for 126s.
You can see that theet are 4,5mm large too.
The wiring diagram:
Note:pin sensor 1 is + and pin 5 is -,if not the ignition won't spark.
Another view of the  wiring diagram:
Maybe some infos about check up are still missing...
See you.
jokke
« Reply #12 on: June 14, 2011, 03:58:33 PM »
I tried using the ignition, but min woun't idle, and hard to start. reving is a probelm to, and it goes BANG some times from the muffler.. so I mounted the orginal ignition again. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
ape20ff
« Reply #13 on: June 14, 2011, 07:42:57 PM »
Hello.
Jokke,I'mnot surprised at all that you had problems.I already hearn of it even if I don't know why.
Congratulations for your project,the suprgharger and megasquirt.
I used to rhink that you weren't interesting in nanoplex anymore.
Have you got a standard 650 engine too?
Did you buy the whole nanoplex ignition?
I'll try to make a sort of manual...
That's the coil:
and that's the sensor:
There's no way to check if you ecu is o.k. without a marelli tester.
However it can happen that there are RF noise owing to something...
Mind the wiring loom and the ignition cables and check that they never touch each other.
Bye
« Reply #14 on: June 15, 2011, 11:07:11 PM »
Jokke, If the engine is running your nearly there, if you study the pictures you can adjust the timing by sliding the sensor on its bracket.
Opposite the sensor is a bracket with timing marks.
Have you tried adjusting the timing?
Thanks ape20ff
