Author Topic: Formulas, for the beardy sorts out there  (Read 1924 times)
« on: July 22, 2010, 11:40:39 AM »
http://www.fortunecity.com/silverstone/chrysler/45/formulas.htm
and from another source:
Cylinder Swept Volume (Vc):
where:
            Vc= cylinder swept volume [cm3 (cc) or L]
            Ac = cylinder area [cm2 or cm2/100]
            dc = cylinder diameter [cm or cm/10]
            L = stroke length (the distance between the TDC and BDC) [cm or cm/10]
BDC = Bottom Dead Center
TDC = Top Dead Center
* Increase the diameter or the stroke length will increase the cylinder volume, the ratio between the cylinder diameter/cylinder stroke called “bore/stroke” ratio.
- “bore/stroke” >1 is called over square engine, and is used in automotive engines
- “bore/stroke” =1 is called square engine
- “bore/stoke” <1 is called= under square engine, and is used in tractor engine
Engine Swept Volume (Ve):
where:
            Ve = engine swept volume [cm3 (cc) or L]
            n = number of cylinders
            Vc = cylinder swept volume [cm3 (cc) or L]
* The units of cylinder swept volume is measured in (cm3, cubic centimeter (cc), or liter)
- Ve  for small engines, 4 cylinder engines is (750 cc:1300 cc)
- Ve for big engine, 8 cylinder engines is (1600 cc:2500 cc)
Compression Ratio (r):
where:
            r = compression ratio
            Vs = cylinder swept volume (combustion chamber volume) [cc, L, or m3]
            Vc = cylinder volume     [cc, L, or m3]
* Increase the compression ratio increase engine power
- r (gasoline engine) = 7:12, the upper limit is engine pre ignition
- r (diesel engine) = 10:18, the upper limit is the stresses on engine parts
Engine Volumetric Efficiency (hv):
where:
            hV  = volumetric efficiency
            Vair = volume of air taken into cylinder [cc, L, or m3]
            Vc = cylinder swept volume [cc, L, or m3]
* Increase the engine volumetric efficiency increase engine power
- Engine of normal aspiration has a volumetric efficiency of 80% to 90%
- Engine volumetric efficiency can be increased by using:
(turbo and supper charger can increase the volumetric efficiency by 50%)
Engine Indicated Torque (Ti):
where:
            Ti = engine indicated torque [Nm]
            imep = indicated mean effective pressure [N/m2]
            Ac = cylinder area [m2]
                L = stroke length [m]
            z = 1 (for 2 stroke engines), 2 (for 4 stroke engines)
θ = crank shaft angle [1/s]
Engine Indicated Power (Pi):
where:
            imep = is the indicated mean effective pressure [N/m2]
            N = engine speed [rpm]
            Vc = cylinder swept volume [m3]
            Ve = engine swept volume [m3]
            ω = engine angular speed [1/s]
Engine Mechanical Efficiency (hm):
where:
            hm = mechanical efficiency
            Pb = engine brake power [kW]
            Pi = engine indicated power [kW]
            Pf = engine friction power [kW]
Engine Specific Fuel Consumption (SFC):
where:
            SFC = specific fuel consumption [(kg/h)/kW, kg/(3600 s x kW), kg/(3600 kJ)]
            FC = fuel consumption [kg/h]
            Pb = brake power [kW]
Engine Thermal Efficiency (hth):
where:
            hth = thermal efficiency
            FC = fuel consumption [kg/h = (fuel consumption in L/h) x (ρ in kg/L)]
            CV = calorific value of kilogram fuel [kJ/kg]
            ρ = relative density of fuel [kg/L]
« Last Edit: July 22, 2010, 11:48:13 AM by Darrell »
Re: Formulas, for the beardy sorts out there
« Reply #1 on: July 22, 2010, 07:22:46 PM »
Had to learn these at tech. school.... was never good at math, still have the formulas in my exercise book :)
Jan-in-UK
« Reply #2 on: July 22, 2010, 07:58:21 PM »
I think my life is WAY easier without having to know what it all means :) :) :) :) :)
www.fsoclub.co.uk
« Reply #3 on: July 22, 2010, 08:24:35 PM »
 :oops: :oops: :oops: Will there be an end of term test , I do not want to fail & be thrown off the forum  :cry: :cry: :cry:
I was trying to fit the 1908, 16 litre, 4 cylinder, ITALA into that set of figures . Is 4 litres per cylinder a big or small engine  ???
