Thanks for the tip mate.
I've tried the multi meter on the fuses (all fine), the bulb (all fine), the bulb socket (all fine) - the only thing is that their seems to be a current coming through from the switch on the brake pedal even when it isn't pressed in. As I understand it the switch on a brake pedal should prevent the current passing through unless it is pressed in. (so completes the circuit and the brake lights come on).
Did you attach another earth wire somewhere then to fix your issue?
