Author Topic: air flow  (Read 2428 times)
air flow
« on: July 16, 2010, 03:53:33 PM »
Does the aire flow in, or out of the engine lid when it is left open as per the abarth etc engine lid mods.
The polish mod opens the top, abarth seem to prefer the bottom of the lid.
There is a vacuum created behind the car so I'm thinking maybe it flows in... and then out when stationary.
Scoops on the aire ducts would aid the fan, but would scoops cut into the sides aid airflow ?
smallcox
Re: air flow
« Reply #1 on: July 16, 2010, 06:51:20 PM »
Hi Darrell,
This is easy for me to answer because as you can see from the pic's pete126 took a few weeks ago my boot is open a couple off inches at the top.
Now on holiday a few years ago in Cornwall I had the fun off putting out a small fire in the engine bay, but just before that while travelling at about 30mph the smoke was being pulled out the top and up the rear window about 20cm before catching the air stream and flowing away. Anyway fire out pants changed and the little car still got us home. :P
Re: air flow
« Reply #2 on: July 16, 2010, 09:06:43 PM »
The reason i ask is i have contemplated many things for the back of mine.
Option 1 which I will persue is to put a scoop onto the air intakes to the fan, this has to create extra posative pressure at cruising speed.
Option 2 was to cut the 'dog bone' out the engine lid, the bit that is inset just above the number plate. Replace it with some tasty mesh, should pull extra air into the engine bay at cruising speed.
Option 3 would be to create a scoop under the car to pull air up into the engine bay, my sump is lower now so as long as it isnt lower than that, it should be no worries.
Option 4 would be to create scoops like yours, a labour of love i fear, the wheel arches were enough work for me! :oops:
The idea is to increase the air flow in the engine bay, and possible ease the vacuum the car pulls...might even get a few more miles per hour out of the beast!
PS the car is not overheating now. But it will need to loose more heat in the future  [-/
Maybe just the ramblings of a madman, but worth airing i guess. From what you say my suspicions are the vacuum is pulled behind the car and pulls air perhaps out the engine lid, that's at 30...wonder what happens faster  :P
« Last Edit: July 16, 2010, 11:53:11 PM by Darrell »
Re: air flow
« Reply #3 on: July 16, 2010, 10:07:04 PM »
when my car ran hot i took the whole engine lid off i drove from my place to northampton via chesham and back again on one cylinder!
smallcox
Re: air flow
« Reply #4 on: July 18, 2010, 06:31:14 PM »
 Hi Darrell,
  The only sure way to remove heat from the engine is an oil cooler, and this should be a serious 1st mod as these engines get hot in standard form on a run, I fitted one and it transformed the heat the engine emitts you can touch the cam cover with your hands and not get burnt even from running at high speed [-/
Re: air flow
« Reply #5 on: July 19, 2010, 09:41:34 PM »
I reckon this thread has the ramblings of three mad men , two just plain mad & one so close to genius he must be part mad  ::). No clues to who is who  :oops:
Thought I would chip in so that makes four nutters  ;)
As it says on the tin (ware) , engine is aircooled or should be as I just found out when my fan "let go" how quickly the heat gets very serious . So the aircooled engine does have an oil cooler in that the fan blows air across the head & barrels ,to the carb & down to the sump vent channels. I have got the little link piece between the main fan housing & sump removed at the moment and on fast tick over the air flow down there is enormous . Little cover on and the air flow at the other side of the sump vents in minimal. Apart from the damage the sump has suffered from probably jacks etc there is a lot of built up muck down there blocking the channels so well worth checking out if you have a reasoably high mileage engine  [-/
Re: air flow
« Reply #6 on: July 19, 2010, 11:06:24 PM »
Yes i need to block that bit that used to go through the sump as I've fitted a bigger ally sump.
I've looked into the oil cooler, just need a bit of a look at how it was done as i'm not paying the silly prices on the net for a 'kit', must take a look at yours smallcox, it seems silly not to fit an oil cooler if it isnt going to cost the earth.
I liked Lad's intake, just a single pipe to the left side of the car, the right one allows air out the engine bay. He mentioned the idea of a scoop too on the left side.Left a whole lot more room in the engine bay!
Anyhow about the nutters! I've never met one with a fiat! And then there's the proper sane ones who have two! Like me! On thursday i take possesion of an 500F [-/ :oops:
Ok ok ...just visit me if I'm comitted ;D
