Author Topic: Kit car with 126 parts, only 17, HELP!!  (Read 3027 times)
matt220992
« on: July 15, 2010, 12:02:21 PM »
Hey guys  :)
I have been building a kit car for my A-Level DT coursework in the style of a Type 69 Lotus (just visually speaking) I have just about finished the chassis and am now faced with fitting running gear, suspension and body panels.
I recently came by a similar project on ebay for sale which contained some great looking parts, particularly the engine which had the diff, gearbox and engine all in one seemingly small compact unit. Perfect. Had a bit of suspension, an entire wiring loom and the engine and stuff.
I drive a Triumph Spitfire 1500 so I know a bit about cars and fixing bit and pieces (quite a lot!  ;D ) but this is project is a pretty steep learning curve for me.
Basically i'm looking for information on the engine mostly, which seems to be an engine cooled 700cc ish motor which appears to be a bit more uncommon. I have been looking for a Haynes manual for it but can't seem to find one that covers a 700cc.
The engine has this information on it:
Fiat
Lancia
M024AA.07.0
7554007
If anyone can offer any help or information it would be greatly apreciated, plus any locals with replacement parts as I feel I may need some!
Many Thanks,
Matt
Eklipze3k
Re: Kit car with 126 parts, only 17, HELP!!
« Reply #1 on: July 15, 2010, 01:53:10 PM »
A quick google of M024AA.07.0 points to this being the BIS engine, which was also used in early Cinquecentos.
That's as far as my knowledge goes, lol.
« Reply #2 on: July 15, 2010, 03:44:56 PM »
Now this is the second time recently where I have seen mentioned a two cylinder Bis engine in an early Cinquecento , was that in the UK   ???
Good luck with the project by the way  [-/
matt220992
« Reply #3 on: July 16, 2010, 10:48:18 AM »
Ok cool thanks guys  [-/
I did find a few things pointing to cinquecentos but I was a bit unsure, because the speedo and small facia with buttons around it is definately from a 126 unless the early cinquecentos used the same parts? Similarly the front suspension I have is a leaf spring which was alos a feature from the 126 and not the cinquecentos so I think I might either have a mix of parts from both OR what is left of a 126p BIS??
Either way has anyone got a Haynes manual or know where I can get a Haynes manual or something to help me out?
I can try and post some pictures of the parts I have if that would help?
fly
« Reply #4 on: July 16, 2010, 11:49:11 AM »
Try:
http://126bis.de/en/126bis.html
Go on the 126 BIS tab, and then the drop down tabs that say select documentation and you can print most of the manual off.
« Last Edit: July 16, 2010, 11:51:37 AM by fly »
Alfons1972
  • sorry for my bad english...
« Reply #5 on: July 16, 2010, 02:22:05 PM »
I try to translate the german wikipedia - article (with a little help from my friend "google translator"):  ;)
Quote
Cinquecento 700
This version of the little Fiat is the oldest. It was built since 1991 in Poland. After this year that car was named “Cinquecento ED” and “Young”.
That car was designed to be a successor to the widely used Polish Fiat 126p. In order to aim this, an attempt was made to produce the car at costs as low as possible. Therefore there is very less equipment in it, compared with the other models.
Depending on the version, the rear window cannot be opend, there's no rear wiper and there are only small wheel covers.
The vehicle is equipped with two types of two-cylinder engines:
The 704-cc carburetor-engine (FOS Lodz or Weber) with engine number 170A.000 without catalyst with 23 kW (31 hp),  the 704-cc carburetor-engine with electronic control (Aisan) with the engine number 170A.046 with catalyst and 22 kW (30 PS ).
This engine comes from the Fiat 126 BIS. It is a two-cylinder carburetor-engine which is arranged horizontally.
The gearbox in both variants is a four-speed manual transmission and is longitudinally arranged in the vehicle.
The Cinquecento ED at 703 cm³ was manufactured from December 1991 to October 1998 and was mainly intended for the Polish market, but also was available in Italy. On the German market, the model was not formally offered by Fiat.
What could be interesting (but I am not sure): I think I've read somewhere, that the 700ccm- cinque had the same bore as the BIS. And because of that it needs to have a different crank with higher stroke.  :P
« Last Edit: July 16, 2010, 02:26:11 PM by Alfons1972 »
Fiat 500 R
Fiat 500 giardiniera
« Reply #6 on: July 16, 2010, 07:43:14 PM »
This is a picture of the engine in the Cinquecento.
Looks to be allot more pipe work than the Bis
Heres a sweet sounding Bis engine in the Cinquecento 700cc.
http://www.youtube.com/watch?v=etNDNOZe3P4&feature=related  :P
« Reply #7 on: July 16, 2010, 08:48:40 PM »
I just love doing these "Spot the Difference" competitions  ::)
I have found 139 so far  ;D ;D
So there really was a 2 cylinder Cinque but did it make it to the UK  ???
« Reply #8 on: July 16, 2010, 09:11:02 PM »
Doesnt look like the thermostat is in the same place on the cinq.
Allan
« Reply #9 on: July 16, 2010, 09:20:12 PM »
Is the electric fuel pump and pressure regulator standard on a Bis?
Allan
« Reply #10 on: July 16, 2010, 10:01:09 PM »
it would be great if there was a pic showing underneath these cars to see the differences.
