Author Topic: NGK spark plug  (Read 1452 times)
deda
NGK spark plug
« on: July 14, 2010, 11:33:43 AM »
Hello
I am new on this forum ,I am from Belgrade Serbia,student,sorry becouse of my english :)
I buy Ngk spark plugs BPR6HS ..and i want to ask ..is that correct spark plug? I have fiat126 650ccm from 89"I plan also to put electronic ignition
Thank you
smallcox
Re: NGK spark plug
« Reply #1 on: July 16, 2010, 07:11:57 PM »
Hello and welcome,
I believe the NGK plug you have is the correct spec just need to check the thread length because there are BPR6HS and BPR6ES. I only use NGK BPR8ES and never had any problems with them.
PS the number refers to the heat range, higher the number the colder the plug 6 is good in a standard engine and with the copper core they have a wider heat range compaired to other makes. ;)
Cheers Steve
deda
Re: NGK spark plug
« Reply #2 on: July 17, 2010, 01:15:44 AM »
thank you ,I will check for lenght of spark plug is that correct.I have some very good schematics of electronic ignition and if somebody needs i will send on e mail.Thank you
gertjanx38
Re: NGK spark plug
« Reply #3 on: July 17, 2010, 07:50:21 AM »
i would like to receive the schematic.
[email protected]
smallcox
Re: NGK spark plug
« Reply #4 on: July 17, 2010, 11:16:16 AM »
Hi again,
Just checked the plugs again and the BPR6HS are the correct length, the ES is the longer thread which I use not in the 126 but Triumph engine.
Cheers Steve [-/
