Fiat 126 Chat
Oil pressure testing.
Pages: [
Topic: Oil pressure testing. (Read 1650 times)
on:
July 12, 2010, 07:54:05 PM »
As I was having problems with our mk2 Golf oil pressure light which was flashing like a xmas tree, I decided to do an oil pressure test. All seems to be fine there and I`m happy with the readings.
Anyway while I had the tools I decided to do a check on the 126s. The one with the rebuilt engine I bought recently was showing about 3.2 bar=45 psi on idle from cold start. The readings only went up slightly with higher revs. On the other one which is a 73 model with 21k mls on the engine it was showing 3.5 bar=50 psi.
I was wondering if anyone else checked they oil pressure before, and what kind of readings they got. Just so I have a rough idea what a decent reading is.
Re: Oil pressure testing.
Reply #1 on:
July 12, 2010, 08:09:36 PM »
Mine read 40 psi fairly constantly.
I don't think you have a problem but I'd check and clean filters
Not the only African in the village
Reply #2 on:
July 12, 2010, 08:21:50 PM »
I thought it was decent, so I`m happy. The filter and oil are nice and clean, so all should be right [-/
Was surprised about the Golf. When I fired it up on choke was reading 100 psi at around 2000 rpm, once settled to 800 rpm 75 psi.
Allan
Reply #3 on:
July 16, 2010, 07:59:30 AM »
From the workshop manual.
Lubrication pressure at 212 degrees F 35.5-43 psi ( 2.5-3.0 Kg/sq cm )
Allan
smallcox
Reply #4 on:
July 16, 2010, 07:29:50 PM »
Checked my engine pressure several times and the gauge reads around 38psi at idle when cold and not much more with engine speed
Pages: [
Fiat 126 Chat
