Author Topic: Starter Cable A/C info  (Read 2289 times)
ciccio
« on: July 07, 2010, 06:47:27 PM »
Hi Guys the 650cc(into my 500L)  transplant is coming along nicely,however please may i ask for a little guidance?
1)Do i need to swap starter cables from a 500 one to a 126 one?
2)Have seen numerous fuel returns-which is best?
3)Gen light is illuminated-alternator that i have fitted allegedly refurbed-any ideas?
Thanks guys
Ciccio
Re: Starter Cable A/C info
« Reply #1 on: July 07, 2010, 07:30:25 PM »
Off the top of my head I reckon that you will be fine with all the cables except handbrake. the starter is just rotated so no linear change.
As for fuel return I would probably go for metal & as it is only an overflow return I reckon that a piece of copper brake pipe with a flare on the end and a flexi hose with clips would do nicely.
As for electricals , ouch ! you will have to get the multimeter guys for that one  ::)
« Reply #2 on: July 07, 2010, 09:56:15 PM »
I was supplied a 500 starter cable in error for my 126. It doesn't fit, the mounting/stop is in the wrong place and it is shorter.
All my altenator has is one big thick posative wire and a thin one i assume is the light?
phreak97
  • Niki!
« Reply #3 on: July 10, 2010, 01:36:03 AM »
you dont actually need a fuel return, you can just block it off and it will work fine.
Im not that familiar with the generator setup in a 126, does it have an external regulator?
Did you just connect the wires up or did you follow a guide?
Theres probably more to it than just connecting it in, id say you have to get rid of a regulator which is probably mounted to the side of the engine bay somewhere.
phreak97
« Reply #4 on: July 10, 2010, 09:11:02 AM »
I dunno about generators, but the altenator has a regulator bolted to the foot which is kinda part of the altenator
phreak97
  • Niki!
« Reply #5 on: July 11, 2010, 09:36:06 AM »
yeah I dont think generator models are like that, a generator regulator usually has a number of wires coming out and is not solid state so vibrations are bad for it, hence mounted on the body of the car not the motor. you cant run the alternator through the original regulator, you've gotta change the wiring.
phreak97
« Reply #6 on: July 11, 2010, 09:55:40 AM »
I thought all 126's were altenators??
How come you got generator wiring on yours?
I know mine has a regulator bolted to the inner left engine bay, it looks a bit like a generator regulator but i believe most were quickly converted to a solid state regulator bolted to the foot of the altenator. Somehow the old regulator has not been removed and bypassed.
I figured bugger it, it isn't broken so leave it alone, although wouldnt mind removing it as it would be a better spot to mount the coil as the coil being on the right where the exhaust heat is, cannot help it's case much.
I wonder if this is what you have?
phreak97
  • Niki!
« Reply #7 on: July 11, 2010, 01:45:42 PM »
I think the early ones are generators, but thats kindof irrelevant anyway cos he's got a 500 not a 126 :p
phreak97
« Reply #8 on: July 11, 2010, 04:52:57 PM »
If it's the 650cc it be an alternator, which means you'll have a bit of re-wiring to do.
As long as you're sure it's all connected up ok, i would suggest replacing the voltage regulator. They're usually the first thing to wrong with the charging system and are quite cheap.
« Reply #9 on: July 11, 2010, 06:00:43 PM »
think he said it was a 650 going into his 500 :oops:
phreak97
  • Niki!
« Reply #10 on: July 12, 2010, 12:16:52 AM »
darrel, yeah thats true, so he's connecting an alternator into a car which is wired up to take a generator. Its definately got an alternator now, its just a matter of whether his wiring has been modified to suit or not.
phreak97
« Reply #11 on: July 12, 2010, 09:41:43 AM »
got it in one :P
phreak97
  • Niki!
« Reply #12 on: July 12, 2010, 12:12:23 PM »
lol i thought i was telling you that.. It wasnt a question.. Im confused lol.
phreak97
