Author Topic: Oil cap retention  (Read 1519 times)
Oil cap retention
« on: June 28, 2010, 03:13:10 PM »
I've just drilled a little hole in the side of the oil cap and into a bit of tinware. Inbetween the two holes I have placed a spring to keep the cap shut and firmly in place.
This is because I lost a cap the other day which covered my engine bay in oil :( anoying so figure I'm not going to loose another [-/
Thought I'd share that  :oops:
Re: Oil cap retention
« Reply #1 on: June 28, 2010, 03:38:12 PM »
Thing is , why did it shed the cap  ???
I found the cap was loose on my high mileage engine. The locating lip on the underside of the oil filler rim had worn badly so the cap was not located properly. The internal washer for the pressure relief valve had almost worn away also. So fitted a new cap and with the standard rocker cover you can "adjust" the locating lip with an adjustable spanner  [-/
« Reply #2 on: June 28, 2010, 04:09:41 PM »
Yeah on my standard tin rocker cover I never had any problems but these alloy rocker covers....
There's not alot one can do other than what I've done.
There should be a stop of some kind, but the cap just keeps turning!
Think I'm going to revive my ally welding set-up and weld a stop onto the silly thing  :oops:
« Reply #3 on: June 28, 2010, 10:42:30 PM »
darrel you need to buy an after market filler cap like this
http://www.500mania.it/ns/index.php/store_gbr/abarth-oil-cap.html
then you will have no worries.
« Reply #4 on: June 28, 2010, 10:51:04 PM »
Hi Mick, that's the very one I had, and now have another. I dunno if your ally rocker cover is the same as mine, I got the extended rocker cover.
I lost the cap on the M3 miles from home.
Like I say there is no stop on the cover for the cap to stop turning against so it's a bit of guesswork as to how much to turn the cap. Now I've sprung the bugger...it's not going anywhere :oops:
