Author Topic: Lowering the front of an a/c  (Read 5045 times)
Allan
« on: June 26, 2010, 10:43:58 AM »
Hello again. I am interested in the varying theories on the lowering the front end of a 126.  I'm looking for between 30 and 40 mm with the bonus of giving me just a small amount of negative camber. Just looking at it, reversing the eyes on the main spring leaf would be an easy if not expensive option as would be retempering the main leaf. I don't know that I'm that flash on the idea of grinding away the spring mounts and from what I have read on this forum the gain is only 10 to 15 mm. I would like to retain the same or similar spring rate. Looking at the front of the car I see it would lend itself to a fabricated front end and I see tha Nanni make one, but at 875 Euros with shipping added would cost me more than I paid for the car. Any suggestions with the gain and pain would be appreciated.
Allan
Re: Lowering the front of an a/c
« Reply #1 on: June 26, 2010, 02:40:16 PM »
reducing the height of the spring mounts is easy and costs nothing but the time doing it getting the original spring turned over and retempered is cheap enough to do and will give you a decent drop for little cost if you replace the front shocks for rear shocks it will make the front lower and harder. if you are interested in a reverse eye leafspring at low cost have a look on the 500 mania site.
« Reply #2 on: June 26, 2010, 11:08:11 PM »
My local truck spring repair shop has quted £40 to change my existng front to a reverse eye, strip and rebuild included.
gsxr126
« Reply #3 on: June 27, 2010, 12:10:52 AM »
make sure you get the suspension geometry right. You may get negative camber after lowering the leaf spring but check the angle of the top control arm. If it's still angled down after lowering, you will induce positive camber under cornering - not good.
On the ifs front, here's the cheapest one i found on ebay - 1185USD
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290146905016&viewitem=&sspagename=STRK%3AMEWAX%3AIT
I'm fabricating an ifs for my car and have done a few backflips on final design. I've managed to get the camber change to a minimum - 1.5 degrees through the whole suspension travel and happy with it now. I also used motorcycle coil overs to replace the shocks.
I've had quotes here in Sydney to do the rev-eye and retemper for about $250 but there are also some on ebay. Here's one
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=220567242476&ssPageName=STRK:MEWAX:IT
Good idea Ralph. I didnt think of going to a truck spring repair place, just went to pedders. I will try get a quote this week but I cant see it being the equivalent of 40 pounds somehow. Thats a bargain
« Reply #4 on: June 27, 2010, 12:14:02 AM »
I had one done about three years ago but did not have it on the car for long, It worked fine and was a little softer the only reason i took it off and replaced it with the proper manufactured reverse eye spring was a safety issue, On the standard spring there is a safety leaf, Fiat this for a reason this wraps round the eye of the main spring and give extra support to the eye, its designed to catch the suspension in case the eye at the end of the main spring shatters, and gives you a fighting chance of stopping safely if it should ever happen.
When they reversed and re-temper my main leaf the safety leaf can not be made to fit so they cut the ends off, so their is no extra support for the eye, you could get them to make a new safety leaf but for the extra cost you might as well buy the one thats made for the job.
Thought i'd just mention it, Also there maybe an insurance issue if anything happens.
Allan
« Reply #5 on: June 27, 2010, 11:07:15 AM »
All those points are very relevant and taken on board. Your point Pete about the safety leaf is very good but I would actually like it to be a little softer in the front if possible. The IFS that Daniel would be a massive design and build exersize and then as he says you might not get it right. I have available to me a spare leaf spring so I may look at getting that reshaped. But aren't those IFS set ups that are available pure 126 porn. Haven't heard from Rustys Uncle on this one yet though. Thanks for you ideas and thoughts and any more are most welcome.
Regards
Allan
gsxr126
« Reply #6 on: June 28, 2010, 01:45:24 AM »
There are 5 & 6 leaf spring setups on this site (this is a real 126 porn site) may be what you're after in terms of softness. Cant give any advice on how soft or hard they'd be though. Maybe someone on the forum has tried these???
http://www.fiat500sport.com/front-and-rear-suspension.html
« Reply #7 on: June 28, 2010, 10:36:10 PM »
http://www.500mania.it/ns/index.php/store_gbr/prodotti/suspensions-and-brakes
i have been running on one of these and they are fine and bloody cheap too!
gsxr126
« Reply #8 on: June 29, 2010, 02:24:54 AM »
that is cheap, 5 or 6 leaf, Bis13???
Allan
« Reply #9 on: July 01, 2010, 09:53:10 PM »
Another couple of questions that someone may have an answer or theory to. Do the 500 and 126 share a front spring? I see in the specifications that the 500 has a front tread of 1.121 metres and the 126 1.142 metres, meaning the 126 is wider by 21mm or just over 3/4 of an inch (13/16 to be exact). All the reversed eye springs for sale appear to be for 500. Would fitting one of these to a 126 increase the postitive camber?
What about taking some of the bow out of the first and second leaves?
I would imagine that any lowering job will mean new shorter bump stops. The clearance between the bumpstop and spring at the moment is 20mm so lowering it by 25mm would mean it was sitting on the bumpstops which is not desirable. I know some Minis had rubber cone suspension but the would be ridiculious for a 126.
All suggestions and comments are appreciated.
Allan
Allan
« Reply #10 on: July 01, 2010, 10:07:12 PM »
I have just rethought some of that. If I reverse the spring eyes the spring will retain the same gap to the bumpstop.
Allan
« Reply #11 on: July 01, 2010, 11:47:36 PM »
Just got a price to reset front spring to whatever I want. NZ$80. Thats about 37 pounds at todays exchange rate. If you Aussies want to know where let me know. Freight to and from might be your problem though.
Regards.
A happy Allan
Alfons1972
  • sorry for my bad english...
« Reply #12 on: July 09, 2010, 02:26:26 PM »
and think of that, it helps you lowering your car about 15mm:
http://www.500forum.de/wbboard/attachments/00000001876__8890__Vergleich%20Lagerb%F6cke%20hoch%20-%20tief.JPG
what will help you lower your car is, to restore your front leaf spring. You have to decompose it (be careful!) and to clean it from rust and paint. I used an steel-brush on an "Winkelschleifer" (Flex, what is that in english???) to make it rust-free.
then you should not paint it but you should use a water-resistant fat for lubrication.
look at my pics:
http://www.500forum.de/wbboard/attachments/00000001876__8139__250320103219kl.JPG (that's what it looked before)
http://www.500forum.de/wbboard/attachments/00000001876__8140__250320103220kl.JPG (right: before; left: after cleaning)
my car is now much softer in front and much lower...   8)
about the positive or negative camber look here: http://www.racingaspirations.com/?p=286&tcx=169&tcy=98&thx=304&thy=98&bcx=79&bcy=197&bhx=307&bhy=273
in the drawing is the original Fiat500 geometry, just use the green arrow to simulate the change of the camper when lowering your car.  ;)
« Last Edit: July 09, 2010, 02:45:59 PM by Alfons1972 »
Fiat 500 R
Fiat 500 giardiniera
Allan
« Reply #13 on: July 09, 2010, 10:46:17 PM »
Thanks for that Alfons. I will look into it.
Allan
