Author Topic: REDEX  (Read 4228 times)
REDEX
« on: June 22, 2010, 09:12:33 AM »
The petrol additive REDEX seems to have been around since the dawn of time. I have used it on occaisions. My old mate used to swear by it as a sort of instant de-coke agent. The idea was , drive to a secluded open space , get engine up to full temp , remove air filter then with the engine on high revs tip neat Redex into the carb.
Anyway although I have always been a bit sceptical about additives I was in Tesco last week & noticed it at half price so for £1.80 I though I would get some just in case I had a use for it.
Now the non Fiat bit. About 2 years ago I treated myself to my first ever brand new (but cheap) motor mower which had a trusty Briggs & Stratton engine. I was never happy with the way it ran & it seemed to be getting worse. When it was coughing & spluttering this week it ran out of petrol. When filling the little tank I added some Redex & finished the grass. Did not notice too much but the next day I did some more mowing and the little beast ran as sweet as a nut  [-/
gsxr126
Re: REDEX
« Reply #1 on: June 22, 2010, 09:58:58 AM »
And for the gearbox I would suggest "Nulon G70 Manual Gearbox & Differential Treatment". I replaced my oils with Nulon stuff and while i was at it decided to put a treatment thru the box. When i undid the g/b sump plug i noticed five teeth stuck/magnetised to it.
Thought this looks bad but it was driving ok with no signs of gears jumping. I'm sure the teeth are from 1st gear as its a little awkward to shift into 1st from neutral and it has a louder than usual whining.
Anyway filled the box with 1 litre of Nulon 75W-90 gear oil and 125mls of the G70. The difference was amazing. The shift feel improved 1000%, 1st gear whining is less than half as loud. It still shifts awkwardly into 1st from neutral but i'm sure thats the missing teeth.
Dont know if you get Nulon products in the UK as they are Aussie made. They basically do what they say and have a range of products that i rekon suit the 126 perfectly.
I also used Nulon seal softener in the engine as the seals had an annoying leak - not enough to warrant pulling the engine out and fixing, but enough to piss you off. After about 550ks the oil leaks have stopped completely and as its suitable for g/b / tranaxles i will be using it in the g/b at its next service.
Re: REDEX
« Reply #2 on: June 22, 2010, 10:38:08 AM »
 :D On the NUlon-Uk website they have a product in an aerosol called 'start ya b*******' Instant engine starter ;D ;D ;D :oops:
Allan
Re: REDEX
« Reply #3 on: June 22, 2010, 11:00:24 AM »
Ah good old Redex. I can remember when some cars had a container of Redex or similar under the bonnet and it was metered into the carb. In those days we called it upper cylinder lubricant. But also back then we would take heads off and "decoke" an engine. I've also done the Redex down the carb trick like Rustys Uncle describes. Anyone who has seen a few engines that burn oil wlii tell you that the piston tops are clean of carbon. Modern engine design, fuels and lubricants means that this is now a thing of the past.
Allan
Re: REDEX
« Reply #4 on: June 25, 2010, 04:44:49 PM »
Some oils are now half price in Tesco  [-/
Re: REDEX
« Reply #5 on: June 25, 2010, 09:10:12 PM »
i bought some ....extra virgin olive....
Jan-in-UK
Re: REDEX
« Reply #6 on: June 25, 2010, 09:32:51 PM »
hi hi hi :D
www.fsoclub.co.uk
Re: REDEX
« Reply #7 on: June 28, 2010, 07:19:58 AM »
Redex about 90p unleaded addititve too. Tcut for £1.20  :D But only in the petrol station, it's more expensive in store.
stobart16gears
Re: REDEX
« Reply #8 on: November 16, 2010, 12:52:57 PM »
There are a few types of Redex....
Fuel Tank Treatment
Carb Cleaner
Injector Cleaner
neilW
Re: REDEX
« Reply #9 on: December 01, 2010, 12:26:11 PM »
I think I had so much sh1te in my fuel tank and engine its all clogged up somewhere and stopped my engine working!?
 :cry:
