Author Topic: 126 a/c exhaust  (Read 4087 times)
Allan
126 a/c exhaust
« on: June 12, 2010, 11:47:07 PM »
I am curious to know who has what theory on 126 exhaust systems. The first thing to remember is that I can't just pop into somewhere and look at or stroke these things because I'm too far away. And there is none of this stuff in NZ for me to look at so I will have to take advice from afar.
1. Are the 500 600 and 650 exhaust systems all the same? If they are different where is the difference?
2. Who makes the best aftermarket system and why?
3. What should I be looking for in an exhaust system? I intend to keep my 126 "almost" standard but will do a little head work and use a warmer cam. At this stage standard carb but will rejet if required.
4. What should I pay and where should I go looking for one?
There are some very pretty looking systems for sale but are they well designed and made. I ran a 500D with all the baffles (can't remember if it was the pipe or plate system) removed on which I replaced the outlet pipe with a piece of inch and a half pipe. This made a lot of noise but seemed to help the breathing somewhat. I am open to advice and suggestions.
Allan
Re: 126 a/c exhaust
« Reply #1 on: June 13, 2010, 01:26:55 AM »
1. Firstly, the Fiat 500 used a 500cc and a 600cc engine. It differed from the 126 engine by size, and the starter motor of the 500 was positioned at 12 oclock (the 126 650cc was positioned at 3 oclock.) This changes the position of the cowling heater pipe, which results in a different exhaust pipe. the 500 exhaust wont work well on a 126 650cc and vice versa, I'm not sure about the 600cc, maybe someone else can clarify.
2. No idea
3. No idea
4. There was a website in the UK for buggies based on the 126 engine they spent allot of time working on diy tuning of the 126 aircooled and it made for great reading. unfortunately the site is no longer available, but I remember their section on exhausts. They tried removing and repositioning the baffle plate to gain the best results from a standard exhaust. Although I can't remember the angle and position of baffle they said was best, I can remember that they eventually concluded the best exhaust was to wekd a cherry bomb in place of the exhaust. Noisy, but apparently aided performance better than any other aftermarket they tested.
Michael
smallcox
Re: 126 a/c exhaust
« Reply #2 on: June 13, 2010, 03:13:31 AM »
 Hi, well i'am going to have my 2pence worth,
  When looking for an exhaust I believe you require something thats not going to make you deaf "I SAID DEAF" even the original exhaust is to noisey at high speed in my opinion. >:(
 I like a sporty exhaust note to add to the fun but on long journeys become tiring.
The problem with the exhaust made for the 126 is they all bolt to the engine which restricts how much silencer you can strap there and make it last, so the manufactors make them restrictive to help silence the exhaust note (no good for performance).
  I have made an exhaust in the past with two straight through silencers but it broke quickly because I just couldn't get a good brace around the system for support. :(
I have seen this buggy web site in the past and remember the cherry type system used (no good for road use and not much scope for extraction of gasses). I believe you require a gas free flowing system that act as an extractor system with primary pipes joining together then through two free flowing silencers in series, sadly these have not been developed by any company for the 126. :(
I had a bash at making this type off system myself, didn't look pretty but worked well. The primary pipes joined together and then passed through a flexible joint then a full exhaust system mounted on rubbers hung under the chassis. On a long run it was better than standard exhaust note (not booming inside) and performance was up and the car itself felt more refined in a way (less vibrations). I used 1 and half inch pipe after the primary pipes so good gas flow would be obtained but small enough to have the slug off gasses passing along the pipe help extract the next discharge off exhaust from the exhaust valve when it opens (this is how an performance exhaust is supposed to work) [-/
I quess you can have one like this made but would be expensive ,I got a quote off £400 4 years ago, if you are handy with a welder there are plenty off places that sell build your own systems parts.
 I Know there are some well built systems for the 126 but your going to need ear plugs ???
Hope this helps, Steve
« Last Edit: June 13, 2010, 03:15:36 AM by smallcox »
Aaron
Re: 126 a/c exhaust
« Reply #3 on: June 13, 2010, 04:10:04 AM »
Have you tried Ludevit & Martin at www.126fan.sk?  From the contact I've had with them, they seem to be into tuning the original 126 engine amoungst other things.  They should be able to point you in the right direction, even be able to source you the bits at a reasonable price over what you may be able to get locally in NZ.
Re: 126 a/c exhaust
« Reply #4 on: June 14, 2010, 01:50:53 PM »
I discovered the difference between the 500 & 126 exhausts when I had to replaced the one on my 500L for the last MOT. I had 4 new or good used exhausts which all turned out to be for the 126 engine so did not fit because of the heater outlet. However I did find that a little strategic "tip-tap" with the round end of a ball pien hammer sorted out the problem then the heat shield above the exhaust box did not fit but I discovered that a little trim on a 126 one sorted that problem. Also out of interest to 500 owners , the lower engine bay cover from a 126 will also fit a 500 so the louvres will let a bit more air circulate in that hot engine bay  [-/
Re: 126 a/c exhaust
« Reply #5 on: June 16, 2010, 09:46:15 PM »
I've only seen sport exhausts for 126's on axel gerstl. They seem to be good quality types, just a bit pricey (not to mention postage....) :oops:
gsxr126
Re: 126 a/c exhaust
« Reply #6 on: June 24, 2010, 10:44:02 AM »
I've looked into buying an exhaust from o/s Allan. With postage etc... it ends up being an expensive excercise so I'm looking at getting a complete system made for similar money, you know, buy Australian. But - no one here in Oz knows how to go about making an exhaust that will suit my requirements. I share all of smallcox' sentiments about the std exhaust and also believe that less vibrations in the exhaust will make the car feel more refined.
I guess I'll just have to try getting all the specs myself and get it built by someone.
Smallcox, do you know how long the primary pipes have to be to get the negative pressure wave happening? I was thinking of tuning the primaries then feeding into a glass packed muffler with the std diameter so I can use the std muffler mounts.
smallcox
Re: 126 a/c exhaust
« Reply #7 on: June 27, 2010, 12:53:44 PM »
Been on holiday so sorry for my absence,
Primary lenght off the header is down to how your going to package the system, different length primary pipes may effect your power curve but on an engine which you mentioned above i guess longer the pipes can be before they join would be benificial as shorter pipes are normally built for high reving fire breathing engines with radical camms. Use near the original diameter pipe for standard engine or a couple mm bigger for fast road use, because smaller pipes keep the hot gasses travelling faster for that all inportant extration effect your sorting for.
The biggest problem for anyone building an exhaust is making it last because there is so little room to bolt all the componants and vibration brakes the pipes. As I mentioned above I bolted the header to the side off the engine with a heavy duty clamp then used flexi exhaust and mounted in series two straight through silencers on rubber mounts. The only problem being it reduced ground clearance for lowering the car so you can only drop the car 1 inch maybe 2 before speed ramps in car parks become a problem. If your going to use fibre packed boxes these can be smaller as they muffle sound better than air boxes size on size. I do have an exhaust here that I made but no camara at presant so unable to post picture. SORRY.
Allan
Re: 126 a/c exhaust
« Reply #8 on: June 27, 2010, 07:54:16 PM »
Thanks Guys,
There is a miriad of different systems available from a great variety of suppliers in different countries. There is nothing new available that I can find in NZ or Australia. There is a guy in Napier NZ who imports this sort of stuff who has some more sports types coming soon so I will look at that option. I've tried making them myself in the past but ran into problems of vibration breakage. Keep the comments coming please because they all make interesting reading.
Allan
AlleyNiki
Re: 126 a/c exhaust
« Reply #9 on: April 14, 2011, 12:43:23 PM »
Hey guys,
What would be the best exhaust to fit on the standard air cooled 650cc?
I want to fit a camshaft with longer opening times on it, and maybe a bigger carb to replace my weber 28imb.
And what is this 'cherry bomb' exhaust?
I know that this is discussed all the time on this forum and I 've been looking for answers but there is SO MUCH INFO HERE!
AlleyNiki
Re: 126 a/c exhaust
« Reply #10 on: April 14, 2011, 01:36:29 PM »
Not that I'm complaining mind :)
