Author Topic: Disc Brakes for 126 a/c with 98 PCD wheels  (Read 3671 times)
Allan
« on: June 10, 2010, 03:59:39 AM »
Hello again
Can I fit a front disc brake set up on my 1981 126 652. I have access to other model Fiat parts so would like to know if I can source all the parts I need from other fiat models. I have seen photos and heard mention on this site.
Allan
gsxr126
Re: Disc Brakes for 126 a/c with 98 PCD wheels
« Reply #1 on: June 10, 2010, 05:03:19 AM »
Que Rusty!!!
« Reply #2 on: June 11, 2010, 05:44:51 AM »
If you do a search in this section you will see that I have written loads on this subject. The conversion is easy if you run 13" wheels & gets a little harder if you go down ti 12"  [-/
Allan
« Reply #3 on: June 11, 2010, 08:42:23 AM »
I have now done that thank you. When you say it fouls the wheel can I assume that you are talking about the origional steel wheel. I was also told that I would have to machine material of the 126 hub to get the disc to fit. As to the disc are we talking about the disc that has fitted everything since the good old 124 saloon? I really do appreciate your help on this. It looks like it could be an excellent engineering exersize. Late model 500/600 not imported into NZ so I am looking at early Uno. What about ventilated Uno Turbo or is that being silly. With a small horsepower car and light weight one would need a soft pad.
Thanks again for your help.
Allan
« Reply #4 on: June 11, 2010, 07:20:38 PM »
I know the thread that you are referring to and there are a number of others if you go further back. Yes that was a standard 126 12" steel wheel . Ignoring vented discs there are only two discs that come into the frame , both of which are fitted to a huge range of Fiat cars . A 240 mms and a 227 mms diameter disc. Neither are suitable for a 12" wheel conversion as standard. The 227 disc does not fit direct onto the 126 hub but the 240 one does & needs no mods with 13" wheels. For 12" wheels you have the option of skimming the outer edge of the hub flange or machining the small shoulder inside the disc hub.  [-/
Allan
« Reply #5 on: June 11, 2010, 09:40:52 PM »
Thanks Uncle Rusty.
Unfortunatley I do not have immediate access to parts to do this myself but do the two discs 227 and 240 have the same flange to face offset? What models where each fitted to?
Allan
« Reply #6 on: June 12, 2010, 07:16:59 AM »
The off set is different on the 227 & 240 discs. Easy to get alignment on the 240 disc as you just require about a 3mms spacer betrween the adaptor plate and the caliper carrier. Slightly more complicated on the 227 disc as the off set is about 5mms in the opposite direction to the 240s . I think that I have found a cute way to solve this but just need the time to put it all together. The expensive ready made 12" units that are available here get the alignment by machining away part of the carrier mount area which must weaken it so I do not like that idea.  [-/
As to models that the 227 discs fit I have a list here of about 50 Fiat , Lancia , Seat etc cars that they are fitted to. eg Panda , Uno , X1/9 etc
Apart from getting the discs to fit the hubs you also neen to get the 227 outside diameter taken down to 210 mms if you are looking at a 12" wheel conversion .
Allan
« Reply #7 on: June 12, 2010, 10:41:55 AM »
What model is the 240 disc from?
« Reply #8 on: June 13, 2010, 09:21:59 AM »
I do not have a full application list for the 240s but they are a very common standard part which are fited to many Puntos & all of the Cinquecentos & Seicentos. If you look for them on eBay the seller will often publish a full list.
Just had a quick look myself and I spotted a new pair at £5.99 , buyer to collect in Letchworth. Bargain if it is on anybody's patch  [-/
RSPSTEVE
« Reply #9 on: June 13, 2010, 10:48:22 AM »
Link Rusty..lol
Allan
« Reply #10 on: June 13, 2010, 12:13:12 PM »
Thanks for that. I have fitted plenty, knew they were different but had no idea of their dimensions.
Allan
« Reply #11 on: June 13, 2010, 03:35:50 PM »
Link Rusty..lol
Item number: 120580471073 is this what you meant  ???
Do not know how to do that clever link stuff  :oops:
Eklipze3k
« Reply #12 on: June 13, 2010, 03:44:46 PM »
Link Rusty..lol
Aww poor Rusty :hug:
Click into the address bar where it say http://www.ebay.co.uk etc so that it's all highlighted, then press Ctrl+C to copy, then Ctrl+V will paste that into anywhere you like  [-/
