Author Topic: 4x190 to 4x98 conversion  (Read 2673 times)
Jota69
« on: June 04, 2010, 06:07:30 PM »
I own a fiat 500 with the 4x190 wheel bolt configuration and i want to convert it to 4x98 using 126 parts. Does anyone know what parts i will need to get from a 126 in order to make this conversion? and does anyone have instructions on how to do this conversion?
when I do this i will also be doing front disc conversion using cinquecento parts
Thanks, Jaime
Re: 4x190 to 4x98 conversion
« Reply #1 on: June 04, 2010, 06:45:26 PM »
On the front end you will need to replace the stub axle / king pin assemblies and everything from there out , hubs, bearings & brakes etc. On the rear you will need the parts from the brake backing plates out . I am going to do this conversion on the rear of my 500 to supplement the disc brakes on the front.  [-/
Jota69
« Reply #2 on: June 04, 2010, 07:00:51 PM »
so on the front I need everithing that is atached to the kingpin and in the back from the brake backplate out, I will try to get this parts this weekend.
Thanks for the response.
by the way, do you have any more of the disc brake adaptor plates left? because i will need a set for this car also
« Reply #3 on: June 05, 2010, 06:31:39 AM »
Yes if you just remove the two bolts at the top and bottom of the king pin housing , disonect the brake pipe and break the ball joint it will all come away.
Yes I still have another set of adaptor plates if you require them  [-/
smallcox
« Reply #4 on: June 05, 2010, 07:00:51 AM »
  Never done this conversion myself but Rusty would possible no because i had a conversation with a 500 owner and he changed the rear swing arms complete so the 126 rear bearing hub could be used with larger aliuminum coupler because there is more clearance for the coupler flanges.
 Is this correct Guys?
« Reply #5 on: June 05, 2010, 01:37:28 PM »
The swing arms from a 126 wont fit a 500, the mounting points are different, I had looked into this some time ago when I was putting my 500 together, we had a wealth of 126 spares but not many 500 spares and this was one of the few items I had to source from a 500
