Author Topic: Alloy Wheels  (Read 2857 times)
DC
Alloy Wheels
« on: May 30, 2010, 01:14:35 PM »
i want to put some new shoes on my 126bis was just wondering how do i know which will fit there must be some special sizing thing for the nuts spacing etc . . .
Re: Alloy Wheels
« Reply #1 on: May 30, 2010, 10:36:50 PM »
98pcd is the size for fiats and you can get away with 100pcd if you want to risk it along with wobble bolts. best tip is to try the wheels you want on the car before you buy them to make sure they fit without rubbing or sticking out too far without having to do any archwork.
DC
Re: Alloy Wheels
« Reply #2 on: May 31, 2010, 01:24:39 PM »
Thanks very helpful!
smallcox
Re: Alloy Wheels
« Reply #3 on: May 31, 2010, 07:47:06 PM »
i used some Dolly Sprint wheels from an old Triumph which are 13x5.5j's and used wobble bolts as mentioned above i will measure the off set and post it later but these only just gave enougth clearance between front shock and rear trailing arm when fitted which may help when needing to no the (MAX) ET offset size.
Worm
Re: Alloy Wheels
« Reply #4 on: June 01, 2010, 04:02:04 PM »
Wobble bolts? What do they look like compared to normal bolts, how do they work Steve
smallcox
Re: Alloy Wheels
« Reply #5 on: June 01, 2010, 09:07:59 PM »
  providing the wheel is centred on the hub you can use wobbble bolt that normal allow the use off different manufactures wheel pcd as long as it's not more than a couple off mm difference, ie 126 is 98pcd you can use 96 to 100pcd. Its not the best way to go but they are used sometimes on after market wheels.
Most wheel suppliers have them in stock
gsxr126
Re: Alloy Wheels
« Reply #6 on: June 02, 2010, 03:44:41 AM »
The wobble bolts i have seen have a separate "tapered" part that spins on the bolt. This taper is offset to centre so that when the bolt is done up, the taper offset spins to the spot where the bolt and bolt hole dont line up. This is a very sus way off bolting 100pcd wheels on a 98pcd hub and wouldnt recommend it on a 126 with any power mods. There are other ways of fitting 100pcd wheels, such as offset washers and with wheels that dont have washers you can ask the wheel shop to drill the tapered seat in the wheel to suit a 98pcd. A mate that owns an 850 coupe just had this done( he fitted offset washers to his previous set of wheels) on a set of 17inch wheels.
Worm
Re: Alloy Wheels
« Reply #7 on: June 02, 2010, 05:17:41 PM »
cheers guys ;)
Re: Alloy Wheels
« Reply #8 on: June 02, 2010, 08:51:35 PM »
Took some pics today of my wobble nuts. As you can see the tapered washer floats 360deg round the wheel bolt shaft, I have used them on a few of my cars and never had any problem. One very important point is that the wheel centre bore fits directly on to the hub centre, If the centre hole is more than 58mm (any less and they won't fit) you should be able to buy a set of spigot rings to suit, But ask before you buy ;D
