Author Topic: about them wahers...  (Read 1713 times)
« on: May 26, 2010, 09:41:24 PM »
the smaller one, is there a way round that goes because now I have no oil pressure at all :(
She has new bearings, new oil pump which I checked is meshing into the cam, when I turn the pump manually oil comes out.
I dunno, I'm out of ideas other than something's gone wrong when I fitted the new alloy sump (4litre). It has an 'extension' which is spring loaded with little tabs that go behind the original oil pick-up.
dont think I could have got the bearings in the wrong way so only thing I have changed it the way the washers fit in :-X
I thought the oil pressure sensor was duff so took it out, and to my horror no oil came-out the hole!
Don't worry I'm not driving it, I've run it for about 2 minutes in total and have noticed oil is splashed-up somehow..
Any ideas?
Re: about them wahers...
« Reply #1 on: May 26, 2010, 11:36:03 PM »
Make sure you have no air leaks on the oil pick-up pipe and the extension otherwise you will be pulling air up and no oil.
Here's another pic of the washers behind the front pulley but as i said make sure the chamfer in the centre matches the shoulder where it seats on the crank.
« Reply #2 on: May 27, 2010, 10:12:05 AM »
Hi Pete, thanks for that.
Yes I think perhaps something has gone wrong with this new sump I fitted.
Perhaps the oil pick-up is to blame.
smallcox
« Reply #3 on: May 27, 2010, 10:49:45 AM »
Hi Darrell,
Still got problems with oil pressure, just thinking if there was a reason that caused the original main bearings to fail and although you have replaced the faulty bearings, the cause may still be there..
Petes right with the pickup may be split/damaged or moved but it maybe worth following your oil supply path, this does require removing your sump and possibly cam cover. what about the blanking plugs in the crank etc. :- :- :-
Steve
