Author Topic: The Tin Man  (Read 2717 times)
The Tin Man
« on: May 25, 2010, 06:25:47 PM »
Been pretending to be an engineer again today. The trouble with non standard engines is that they need special treatment. The top tin ware section that normally supports the air filter, both on the 795 ccs Alquati engine and the one I got with the Bambino head & large Solex twin choke carb , needed some work. They both came with what was something like the lid of a large jam jar fixed over the hole where the Air filter sat. Not good to look at & I wanted a smoother look inside & out partly to help the passage of the cooling air. Also the Bambino head one was a major bodge as it still had the inner ducting in place which was not required. So Mr Angle Grinder helped me get them prepped then I had to cut some flat plates to fill the large air filter hole. I thought this was going to be hard work using just hand tools but remembered that I had a nice little "Nibbler" that fits an electric drill. I clamped them in a normal workbench so I could feed the metal in & cut to shape , worked a treat  ;D
Brazed the plate into one cover & welded the other, no reason for the different methods , just having fun  [-/
Re: The Tin Man
« Reply #1 on: May 25, 2010, 06:36:49 PM »
Rusty I did the same, had a lot of work grinding and minor filling to get it to look just right.  They both look good, need to post a photo when they are finished.  You may need to weld a support on for the twins.
Re: The Tin Man
« Reply #2 on: May 25, 2010, 08:14:27 PM »
I've done the same for mine  [-/
I used a honda cx500 carb which has a rubber mounting but thinking of putting a support bracket as well :oops:
Re: The Tin Man
« Reply #3 on: May 25, 2010, 08:47:07 PM »
Well spotted you guys , the one with the throttle mount is for the Alquati which can take the Weber 30 DIC or the Dellorto FZD 32 28 with no additional support. The other one had the throttle mount removed (badly but I have sorted it) & is for the Solex which is too big a lump to just hang out to the side & will need support. I have done the fettling so they are ready for powder coating and the Solex support will be added as an adjustable "bolt on"  [-/
Re: The Tin Man
« Reply #4 on: May 26, 2010, 03:17:35 PM »
Today's project was a Rocker Box Cover for the Alquati engine when fitted with the Weber 30 DIC as the carb fouls the oil filler . Not sure how it was done originally as the engine came without the cover. After much thought II took a standard cover , drilled through the spot welds that hold the inside baffle and removed that. Used the angle grinder and made three straight cuts on three sides of the filler section. Left the side furthest from the carb intact. I could then bend the filler to about 30 degrees away from the carb then welded in new sections to fill the gaps. Trimmed the baffle and brazed that back in place and it all goes together OK. Just need to sort the Breather pipe now  [-/
smallcox
Re: The Tin Man
« Reply #5 on: May 26, 2010, 04:08:53 PM »
This is all good stuff  [-/ keep the pitures comming Rusty
Steve
nrg19uk
Re: The Tin Man
« Reply #6 on: May 26, 2010, 05:52:46 PM »
couldnt you just remove the cap completly and weld the breather straight to the rocker, fill up like they with mercs througth the dipstick or breather???
Neil gargaro
Re: The Tin Man
« Reply #7 on: May 26, 2010, 08:37:31 PM »
 ;D Neil , I have enough trouble getting the oil in the normal filler without making a mess so those options are a bit scary for me  :oops:
Also the filler section incorporates the engine pressure relief system which I wanted to retain intact  [-/
smallcox
Re: The Tin Man
« Reply #8 on: June 02, 2010, 05:12:31 AM »
Hi Mate,
Hate to say this but have you got enough clearance for that carb plus filter in your engine bay? :-  I got a large hole cutter you can borrow to remove your parcel shelf. :P
looks the part [-/
« Last Edit: June 02, 2010, 05:36:20 AM by smallcox »
Re: The Tin Man
« Reply #9 on: June 03, 2010, 03:28:56 PM »
You cheeky boy you ! ;D
I have checked the height with a ruler & it looks tight but the standard thing to do is just drop the engine a centimetre or two at the rear engine mount if necessary  [-/
Alfons1972
  • sorry for my bad english...
Re: The Tin Man
« Reply #10 on: June 11, 2010, 11:15:48 AM »
that way?
Fiat 500 R
Fiat 500 giardiniera
Re: The Tin Man
« Reply #11 on: June 12, 2010, 07:20:18 AM »
Yes , just like that  [-/
Longer studs and a spacer or spacers .
Tomasz
Re: The Tin Man
« Reply #12 on: June 15, 2010, 02:38:43 PM »
Its all looking very sexy!
When I had my panda head and carb with a filter like that it just about cleared the top of the bay but it did knock over large bumps.  Dropping the engine a cm or so would have done the trick and I think yours will be lower than the panda carb anyway.
