Author Topic: end play  (Read 1971 times)
end play
« on: May 25, 2010, 11:32:34 AM »
Is there meant to be a certain amount of end-play on the crank?
Coz mine seems excessive :oops:
smallcox
Re: end play
« Reply #1 on: May 25, 2010, 05:44:51 PM »
Darrell,
 When you mention end play i quess you mean crankshaft end float,
have you measure this end float with a DTI anything under 15thou dont worry to much, however i beleive you replaced these bearing because off oil pressure problems?
If new bearings are used you would expect less than this, check all the parts behind the pulley are sitting correctly including the oil thrower because only the front  bearing controls crank thrust, (never set the endfoat to small as the crankshaft can pinch when you get crankshaft flexing at high revs).
I have not got the standard clearances for crank end float with me at presant
SORRY
Steve
Re: end play
« Reply #2 on: May 25, 2010, 07:21:31 PM »
As Steve said^^^^
I had a similar problem with a Bis engine But i think they are the same This may help ;)
Re: end play
« Reply #3 on: May 25, 2010, 08:12:20 PM »
Thanks a million there  :oops: Think I had may washers round the wrong way  :oops:
Re: end play
« Reply #4 on: May 30, 2010, 10:31:09 PM »
well theres a happy end to a story in there somewhere is it okay now?
Re: end play
« Reply #5 on: May 31, 2010, 06:18:35 PM »
It's running sweet again  [-/
Seems the oil pressure problem was the cause of all the overheating issues :oops:
Once I got the washers right the oil pressure camae strait up.
I took her to Fleet on Sunday with three of us in it to that garage sale. Managed to get an 80/40 performance cam  [-/
smallcox
Re: end play
« Reply #6 on: May 31, 2010, 09:55:25 PM »
Good News [-/
