Author Topic: Windshiel washer help  (Read 2906 times)
Jota69
« on: May 23, 2010, 02:56:45 PM »
I intalled a Bis windshield washer bottle with electric pump onto my 126 that had the mechnical pump, I installed everything but when I activate it I can hear the pump working but no water comes out of the washer jets. I tried reversing the cables on the pump but I get the same results.
I don't know what coul be the problem
smallcox
Re: Windshiel washer help
« Reply #1 on: May 23, 2010, 03:37:32 PM »
Hi Jota69,
I fitted this to my fiat and found that you  may need to blow into the water container with the pump running just to get rid of the air lock present. I take it its not blocked.
failing this maybe the motor to pump drive is u/s
Hope this helps
Steve
« Last Edit: May 23, 2010, 03:51:06 PM by smallcox »
Jota69
« Reply #2 on: May 23, 2010, 03:57:38 PM »
I will try to blow into the bottle to see if that works
Jota69
« Reply #3 on: May 23, 2010, 04:45:09 PM »
I blew inside the bottle whith the pump running but got same results, nothing comes out. Could it be that I got a bad pump?
I blew air inside the hose and air comes out of the jets, I ordered brand new hoses and washer jets to redo the whole system anyway so i hope when that comes in I can intall everythimg and that will solve my problem.
The pump is brand new and when I activate it I can hear in working, could it just be making noise but not pumping anything?
smallcox
« Reply #4 on: May 23, 2010, 05:08:10 PM »
 you can remove the outlet hose from the pump and try it again to see if water is coming out at force, but if like what you say you can blow air through the pipe and out the jets then replacing these pipes will not solve the problem.
still say faulty pump :(
hit the pump while it is running
Steve
« Last Edit: May 23, 2010, 05:09:43 PM by smallcox »
« Reply #5 on: May 23, 2010, 06:16:44 PM »
is the pump wired up properly? just a thought.
Jota69
« Reply #6 on: May 23, 2010, 07:41:07 PM »
There are just 2 wires on the pump, one ground and the other power comming from the switch I installed, I switch the wires around and it still doesnt shoot water out of the jets.
Jota69
« Reply #7 on: May 23, 2010, 07:43:45 PM »
Steve
The pump is brand new and it makes noise when I hit the switch, you really think I have a faulty pump?
smallcox
« Reply #8 on: May 23, 2010, 07:59:48 PM »
Hi again,
ok, remove the pump from the bottle and check the inlet on the pump for blockage (may be packaging blanking plug or paper in there at chance). as its a new pump can you take it back as this does sound faulty, if not you can try and strip it down if there are screws in it and not a pump that is pressed together,
still sound like a u/s pump
Steve ::)
Jota69
« Reply #9 on: May 23, 2010, 09:36:49 PM »
I bought the pump from ebay a couple of months ago so I cant send it back now, I will take the pump out and check for blockage. If its not blocked I guess I will have to buy a new pump
smallcox
« Reply #10 on: May 23, 2010, 10:12:27 PM »
If it is shaged let me know, i Had one the other day and your welcome to it, its the bis one which plugs into the bottom off the bag.
I'll test it before sending it to you.
Steve
Jota69
« Reply #11 on: May 24, 2010, 07:13:44 AM »
Ok sounds good, I might just gotten a defective pump
