Author Topic: Need help with 2 radio wires  (Read 1932 times)
felga
« on: May 23, 2010, 09:50:54 AM »
I wanted to connect the radio and found "+" (permanent- green red), "-" black , and two yellow and yellow red wires connected together, there is no voltage in them. T tested with multimeter and they act like "-" , just wondering maybe they aren`t original cables ?
http://img714.imageshack.us/img714/8243/radioy.jpg
Andy
Eklipze3k
Re: Need help with 2 radio wires
« Reply #1 on: May 23, 2010, 10:33:29 AM »
It's probably a switched live, only comes on with the ignition to stop the radio draining the battery.
felga
« Reply #2 on: May 23, 2010, 10:42:04 AM »
Yes but with ignition on or not they dont make 12v when connected to black "-"
« Reply #3 on: May 23, 2010, 10:49:24 AM »
Can you trace the leads back? perhaps it's the speakers earth connections?
« Reply #4 on: May 23, 2010, 10:50:31 AM »
Turn on the side lights and you should get 12volts, It's the illumination wire for the Radio.
« Reply #5 on: May 23, 2010, 10:55:59 AM »
according to the workshop diagram
Red+Green is the +
Black is the - (is that the black cable snipped off in the background of your photo?)
