Author Topic: think i might have found it  (Read 2107 times)
« on: May 22, 2010, 08:50:25 PM »
The end of the camshaft, where the oil release valve presses is badly scored.
Is this normal?
Re: think i might have found it
« Reply #1 on: May 22, 2010, 09:00:27 PM »
get a pic on . as far as i know this is not normal as the camshaft i removed when i wore out one lobe was okay i reckon the oil pump isnt working properly .
« Reply #2 on: May 22, 2010, 09:04:29 PM »
Thanks I'll try putting a pic up, I alwayes end-up loosing it when I try to make pictures smaller (loosing my patience) :oops:
« Reply #3 on: May 22, 2010, 09:10:53 PM »
I hope this works, I balanced the pump on there so it's in the same pic :-X
« Reply #4 on: May 23, 2010, 06:47:33 PM »
i have an engine in bits in my garage and had a look the oil pump has an alloy ring where it connects to the cam shaft and mine is pretty much the same as yours it was working fine when i took it apart so my guess is its okay. have you took the oil pump apart there may be a clue inside? by the way have you changed the sump for a deeper alloy sump?
« Reply #5 on: May 23, 2010, 07:30:21 PM »
Have you checked the crankshaft bearings yet ???
« Reply #6 on: May 23, 2010, 07:41:24 PM »
Hi yeah changed for the 4 litre alloy sump (extra cooling I thought :oops:)
I'll take a look at the crankcase bearings now.
« Reply #7 on: May 23, 2010, 09:00:57 PM »
Just removed main bearings, found a piece missing about an inch long out of the inner race of the rear main bearing. Put a new one in, pretty sure that's it :oops:
« Reply #8 on: May 23, 2010, 09:15:50 PM »
Was the crank journal OK ? I am slowly rebuilding an engine that had only done a few miles but that rear main bearing had worn right through the white metal and part through the steel liner & the crank was totally shot. Not sure why but every step of the rebuild I check in the original Fiat 500 Workshop Manual  [-/
« Reply #9 on: May 23, 2010, 09:33:11 PM »
I'll be honest, I didnt measure it at all. I had no reason to believe there is any wear as the bearing looked good that came out, but for the fact it was missing about an inch of the one race.
I'm guessing the resultant oil pressure will be an indication of the state of the crank.
I'll fire it up tomorrow and try get an oil pressure gauge onto it. :oops:
