Author Topic: engine problem  (Read 2571 times)
stefanikoss
engine problem
« on: May 22, 2010, 05:38:37 PM »
Why is my fiat only running on one cylinder there is spark on the plug but not fireing on that cylinder it is the rear cylinder
plz help me
felga
Re: engine problem
« Reply #1 on: May 22, 2010, 05:40:06 PM »
I would check valve timing - 0.15 on every valve. Before that check compresion , should be 8 afair.
ANdy
stefanikoss
Re: engine problem
« Reply #2 on: May 22, 2010, 05:47:03 PM »
should it be 015 valve play on every valve
i am from sweden so i am not that good on english
felga
Re: engine problem
« Reply #3 on: May 22, 2010, 05:54:57 PM »
I`m from Poland ;) so no worries with language.
If You have 126 bis 700 it`s 0.15 on all valves
If You hace 126 650 aircolled than exhaust valves - 0.20 and intake - 0.25
Andy
stefanikoss
Re: engine problem
« Reply #4 on: May 22, 2010, 06:08:15 PM »
i have a 595 aircooled 1975 year
felga
Re: engine problem
« Reply #5 on: May 22, 2010, 06:56:42 PM »
600 and 650 is the same 0.20 exhaust and 0.25 intake.
Andy
stefanikoss
Re: engine problem
« Reply #6 on: May 22, 2010, 07:02:28 PM »
thx andy for info
if the valves are correct and everything what could it be then
i shall check them tomorrow and i will let u know if it work or not
thx my friend
felga
Re: engine problem
« Reply #7 on: May 22, 2010, 07:13:21 PM »
Check the compression after You set the valve clerance. In Your case Shoud be between 7.5 -8.0 .
Andy
Re: engine problem
« Reply #8 on: May 22, 2010, 09:10:08 PM »
check that the valves are rising properly if you know the front cylinder is running fine then measure the rise and fall of the rear rockers as i have had the experience of one lobe wearing down so much that the inlet valve did not open properly thus not letting any fuel or a tiny amount into the cylinder but still let any gases that were in the chamber due to the exhaust valve working properly.
stefanikoss
Re: engine problem
« Reply #9 on: May 23, 2010, 08:05:21 AM »
ok i will do that but i tink that there is bad compression in that cylinder
Re: engine problem
« Reply #10 on: May 23, 2010, 09:45:54 AM »
How do you know it's only firing on one cylinder? When the 126 are on one cylinder they run really rough and can only just tick over. It may be just a duff spark plug or HT lead.
stefanikoss
Re: engine problem
« Reply #11 on: May 23, 2010, 02:32:45 PM »
when the engine is running i can take the sparkplug cable off and nothing happens and it is backfireing when the cable is on strange dont u think
