Author Topic: horn not working  (Read 1926 times)
bardy
horn not working
« on: May 21, 2010, 04:15:04 PM »
right at the begining of this week my hornd work nd my gf nd my niece went into my car cos my neice likes to play in the car nd my gf was looking after her while i was cutting the grass, the horn worked then it just stoped  and all i can hear is a clickand it hasnt worked since, i checked the fuses there all ok, i took the button off cleand the springs and plates the button gose onto nd still nothing so i was just wundering if anyone had the same thing and had any pointers to help me get it fixed
tar ashley
DC
Re: horn not working
« Reply #1 on: May 21, 2010, 06:36:02 PM »
have you checked the actual horn? if u have a tester check if theres power getting to the horn terminals if theres a click would suggest some power is getting to the relay i recon u just need a new horn!
bardy
« Reply #2 on: May 21, 2010, 09:15:07 PM »
well i was thinking of putting sumthing bigger on i wunt mind putting air horns on that would be funny little car with the biggist horn to scare everyone in a 500metre radius lol
« Reply #3 on: May 22, 2010, 10:07:53 AM »
If its making a click its either knackered or the connections might be corroded- try connecting it directly to the battery to see if it does the same thing which would indicate a problem with the horn itself- if its ok the check the wiring and clean all of the connections.
9 times out of ten its usually a dodgy or dirty connection.
bardy
« Reply #4 on: May 22, 2010, 09:48:41 PM »
well al have alook on monday after we dun the bathroom but we got a spare horn so i can check with that oen aswell to be sure
126bis1997
« Reply #5 on: May 25, 2010, 08:40:24 PM »
I had same problem
What Idid was sprayed WD40 let it soak for a few minutes and then gently tapped with
a small hammer the horn of course
Horn works fine now
But every now and then I do spray a bit of WD40 just to be safe.
