Author Topic: Raditator  (Read 1361 times)
DC
Raditator
« on: May 20, 2010, 01:03:47 PM »
finally got my car running nice (touch wood) now bloody radiator doesn't cut in and i have to sit with heater goin full blast to keep geno cool but temperature dial thing works so i dont know! Anything i should check eg things i might have undone?  thinking about it now is there a fuse? i'll go have a look now lol
DC
Re: Raditator
« Reply #1 on: May 20, 2010, 01:41:28 PM »
right i've had a look n its operated by a relay n i swapped it with the horn one n the relay is still working but the manual i've got only shows 4 relays and mine has 2 extra ones attached to the side so thought could be one of them.
anyway i can check it now i've put some new ones in some one must know the ins and out of the bis radiator can imagine them being a problem to someone!
Re: Raditator
« Reply #2 on: May 21, 2010, 04:11:23 PM »
Extra relays are for the lights!  You might find that it is the two stage switch on the rad, common problem!  Would recommend wiring in a manual switch.
DC
Re: Raditator
« Reply #3 on: May 21, 2010, 06:32:55 PM »
idk wat i did but playing about yesterday went for a drive and there is was the whirr of the rad think relay might just have been loose or something! thanks alot tho!
