Author Topic: Brake Pipes etc  (Read 1379 times)
Brake Pipes etc
« on: May 18, 2010, 06:35:20 PM »
I have just finished stripping the last parts from the rotted out 126 body shell that I have been breaking. I drove this car home about 40 miles well over 10 years ago straight into my garage where it had been dry stored ever since . I had started to weld the bad parts but decided it was a silly idea and from what I have seen, once the shell was rolled over, I made the right decision as the rot was extensive even though the car had been treated. The scary bit though was that 3 of the steel brake lines broke when I tried to move them  :oops:
So get those copper brake pipes on there & if the MOT man says your pipes are corroded then take it on the chin & sort it because I reckon that one or two pot hole jolts would have busted these so no brakes  :o
Re: Brake Pipes etc
« Reply #1 on: May 18, 2010, 07:12:34 PM »
Changed the front left, rear left long, rear left short, rear right short brake pipes cause there was some corrosion on them or because the brake line nut had rotted onto the pipe  >:(
Why don't they fit cars with copper brake lines in the factory? Much better than  steel ones in the long run...
