Author Topic: Wobbley wheels  (Read 1632 times)
K666STW
  • 704cc of pure fury.
Wobbley wheels
« on: May 18, 2010, 04:48:06 PM »
So just been out cleaning the car and as I passed the sponge over the N/S front wheel I heard a small clunk.  :o
It seems pushing and pulling at the top of the wheel shows some amount of play, It's the same on the other side but not quite as bad.
What could this be? I've check the wheel bolts are on tight but that's as far as I could go.
Eklipze3k
Re: Wobbley wheels
« Reply #1 on: May 18, 2010, 05:24:24 PM »
Kingpins and bearings would be in my list of things to check ...
K666STW
Re: Wobbley wheels
« Reply #2 on: May 21, 2010, 01:50:44 PM »
Kingpins did cross my mind too. Cars been so well behaved the last 12 months aswell.
K666STW
Re: Wobbley wheels
« Reply #3 on: May 23, 2010, 04:17:54 PM »
Well problem part solved. The play was in the hub so have tightened up the hub to lessen the play. Seems to have worked, but should I be worried about what cause the play? The lock nuts hadn't moved so the wear must be from inside?
