Author Topic: knocking from back end  (Read 1681 times)
massa
« on: May 14, 2010, 04:27:44 PM »
hello out there not sure gearbox mountings have gone kerput when i go in reverse or over a bump in road there is a banging from back end when you look at gearbox mounts the rubber on them only seems to be in a east and west seating that is to say any up and down motion of car ie a bump is not absorbed is this how it should be i would ave thought all round rubber is how it should look giving max effect thanks chaps
Re: knocking from back end
« Reply #1 on: May 14, 2010, 06:48:07 PM »
They are designed that way to take out the vibration of the engine if you look at the picture they are a wide upside down V which helps to support the weight of the engine and gearbox, Don't forget that these gearbox supports are probably the originals so that makes them 20+ years old if they are weak, cracked and perished they need replacing and that should sort out the problem ;)
P.S. Did you manage to sort out the Water Leak ???
massa
« Reply #2 on: May 14, 2010, 07:10:03 PM »
hello pete mounting on my car appears different to the picture as i said its supported if you like 3 oclock and 9 oclock in between there is nothing no rubber you can see daylight through gap the picture seems to be a solid rubber that has supports in 3 places  they dont look that old to be honest but you never can tell ye your advice sorted water leak fitted new seal on pump top man thanks
« Reply #3 on: May 14, 2010, 07:25:18 PM »
That's good news about the water leak [-/ do the new seals and packing box just push into place or do they need a special tool ???
If the GB/mounts look O.K. check that the front mount spring on the rear panel isn't broken.
massa
« Reply #4 on: May 14, 2010, 08:32:20 PM »
put it this way they look different to your picture pete as i described ye seal comes on a rubber sleeve with washer i offered it upto its location put a socket over it to gently square it up tapped gently on socket with a hammer once it was square puti impeller on and and allen nut as you tighten nut it pushes seal into its seat once in i took impeller off to see if seal was all the way in i tapped it again but it went no further no leaks now i left oil seal alone leave well alone eh thanks pete back to gb mounts mine are not like yours
massa
« Reply #5 on: May 15, 2010, 04:45:06 PM »
hello pete got drivers side gb mounting off looks not that old all of the pictures i look at seem to have a rubber infil all round mounting ie when held up i can see daylight all round mine your pic and ones on ebay seem solid no daylight thanks dave
