Author Topic: Hard to steer  (Read 1297 times)
Korius
  • aircooled 126 ' 97
Hard to steer
« on: May 13, 2010, 02:16:42 PM »
Hello. I have greased my kingpins 500km ago, but is still difficult to steer the wheels. Where can be the problem?
Maybe i need new kingpins, or i just need to replace gum parts of the kingpins.( need to buy smth like this :  https://webshop.fiat500126.com/?PATH_INFO=/katalog/artikelinfo/533-1-steering_knuckle_repair_kit.html&& )
Re: Hard to steer
« Reply #1 on: May 13, 2010, 06:41:18 PM »
If you lift up the front of the car and see the kingpins wobble then you need to replace them (steering can be hard with wobbly kingpins too...). Could also be lack of oil in the steering mech. (check by removing the plug on the left hand side, some oil should seep out of the hole), flat tyres can cause difficult steering, rotted in ball joints or the steering arm bushes might be rotted in too and may cause creaking noises.
