Author Topic: R/H DRIVE HEADLIGHTS  (Read 2378 times)
RSPSTEVE
« on: May 11, 2010, 09:46:25 PM »
For a 1969 500 , can anyone help?
Steve
Re: R/H DRIVE HEADLIGHTS
« Reply #1 on: May 11, 2010, 11:33:57 PM »
Steve
next to impossible to find :(
best bet is to use RHD lenses with LHD shells
RSPSTEVE
« Reply #2 on: May 12, 2010, 07:39:34 AM »
Thanks chris, are the lenses easy to find then?
Steve
« Reply #3 on: May 12, 2010, 10:16:00 AM »
They occasionally come up on ebay.
Usually scenario is that you use the old ones that's if it's a a UK RHD model. If you have an imported LHD you will have a problem.
I used LHD lights on my 500 and it was never a problem, but I think my MOT man was kind.
« Reply #4 on: May 12, 2010, 04:01:37 PM »
Are 500 the same as a 126. If so I have a set of 126 lenses in my shed.
« Reply #5 on: May 12, 2010, 04:13:39 PM »
My 500L has always had LHD headlamps . Come MOT time I just stick a bit of tape on the lenses then when I get home I take it off for the rest of the year. However as a precaution I have worked out a solution using Triumph 5 3/4" sealed beam units which you can buy cheaply in any motor factors or ebay  [-/
Eklipze3k
« Reply #6 on: May 12, 2010, 04:14:26 PM »
Nope, 500 is round, 126 is oblong
« Reply #7 on: May 13, 2010, 12:39:04 AM »
I fitted Triumph sealed beam units in my 500, I had to grind out a small section of the chrome surround return lip, at the rear to get the unit in place.  I cut down the old light unit fitted it over the sealead beam used the original wire clips etc. it fitted just like the original.
