Author Topic: MPH / KPH speedo  (Read 2450 times)
pwj1695
MPH / KPH speedo
« on: May 11, 2010, 02:50:29 PM »
I'm in the process of uk registering my Polish built 126. All was going well, but now the DVLA want to inspect the car to check that it reads in mph, it doesn't. Does anyone know where I can buy I dial to go over the existing back ground, or can I just stick on some hand written numbers?
Mark
Jan-in-UK
Re: MPH / KPH speedo
« Reply #1 on: May 11, 2010, 04:03:08 PM »
Sticked or written numbers isnt any good. I assume you did an MOT already, was it a problem?
If it wasn't DVLA has nothing to say.
On a separate  note - you can buy mph speedo on Ebay. It takes 5 minutes to swap it.
www.fsoclub.co.uk
« Reply #2 on: May 11, 2010, 04:04:02 PM »
Go to another MOT station. 100% it does not need to read in MPH. In fact for an MOT a speedo doesn't even need to work.
I have had LHD cars with KMH speedos registered here in the UK.
« Reply #3 on: May 11, 2010, 08:57:19 PM »
 I had a car inspected by DVLA few times, but never had a problem, and they never checked the speedo. What they were checking if the chassis number stacks up, and the date on  the glass to make sure it all ties up with the age of the car. This was on old cars with no registration documents, but sometimes they could do a random check on any imported car. I would just put some stickers on. This would be a good guide for you anyway, just so you know when to slow down for speed cameras. Good luck.
« Reply #4 on: May 11, 2010, 09:25:48 PM »
There is no mention of speedometer in the MOT regulations & my car has passed the MOT for the 12 or so years that it has been in the UK. Also many speedos are duel marked even if they are not numbered in the alternative speed rating. So if you have an odd lines on the display they may well refer to MPH speeds  [-/
« Reply #5 on: May 12, 2010, 08:16:41 PM »
i think it may be because its being registered as an imported car and perhaps the laws have changed recently?
« Reply #6 on: May 12, 2010, 08:49:41 PM »
When push comes to shove you really need to replace the speedo for MPH to keep your licence clean, if you search on Ebay you should be able to pick up a 126 aircooled instrument panel, If not you should be able to get away with fitting the CINQUECENTO panel which is very similar to the Polish 650P dials
Jiminwatford is doing them for 14 quid including postage on Ebay,
pwj1695
« Reply #7 on: May 12, 2010, 09:44:16 PM »
Thanks for all your help.
Getting the MOT was no problem, but the DVLA require mph readings so looks like I'll have to sort something out, time to start looking through ebay listings!
