Author Topic: Few questions about my new 126 bis  (Read 2752 times)
felga
« on: May 08, 2010, 10:19:21 PM »
Hi Just wanted to find out few things.
I just purchased 126 bis 1989 in white
The car stood for 2 years. It doesn`t start yet. There is a spark , and it cranks, but there was no fuel. So i detached fuel hoses and blew into one of them (return) and and there where muliple leaks form the inlet hose. I droped the tank and replaced both. I connected them as it should be inlet from the left nipple in the tank and return to the right one. The car starts for few seconds if i put fuel into carb but the pump doeasnt fill up the line into carb, I have transparent fuel filter. I tested the pump and it does push the air and the pulls through the inlet nipple. I`ll connect bigger battery and try it with small container to make shure it`s strong enought.
ANyone have any other thoughts what can be wrong ? Maybe the rod that drives it is worn ?
I`ll post photos of my car in new member section.
Andy
Re: Few questions about my new 126 bis
« Reply #1 on: May 08, 2010, 10:30:49 PM »
sounds like the fuel isnt getting up the inlet- try taking the return off and blowing down it to get the fuel up it- this has worked for me in the past I think you can get an airlock in it and however much you crank it the fuel cant get up in the inlet pipe....
felga
« Reply #2 on: May 08, 2010, 10:38:18 PM »
I did that before. This is how i noticed the cracked inlet hose. But now i cannot get any fuel through by blowing into return hose. I sounds like i`m blowing into the tank . But i pulled the air through the inlet and got the fuel up. Shoud I blow into return until the fuel will start going through inlet hose ? I`ll use compressor , I feel dizzy now ;)
Andy
felga
« Reply #3 on: May 09, 2010, 09:53:58 AM »
I dont know how many types of pumps are there but my feed to the pump (marked in on the pump) is the one closer to the back of the car , not as shown on this photo :
http://126bis.de/sw/bis-10-56.gif
RSPSTEVE
« Reply #4 on: May 09, 2010, 11:49:05 AM »
I would try the big battery too, When i got mine the battery was no good, put my wifes on and it span over super fast and stated easilly, i did put a new 126 battery on and allthough it starts everytime, it does seem slow turning over .
Good luck
Steve
felga
« Reply #5 on: May 09, 2010, 12:04:23 PM »
I took the pump out sprayd it with wd40, and few minutes ago I connected to feed hose, then with crewdriver pushed the bottom where the rod goes, and the pump works fine there was plenty of fuel comming out. I`ll try bigger battery in a second.
I took the rod out , anyone knows what length should it be ?
Mine is 19cm long . If it`s worn it`s not pushing the pump propely.
Uploaded with ImageShack.us
Andy
« Last Edit: May 09, 2010, 12:06:15 PM by felga »
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #6 on: May 09, 2010, 01:14:44 PM »
hi there , i had fuel troubles , even with a conrod and mecanical pump swop ..
so ...  i wired up the fuel pump using the heated rear window switch as suggested , so not only does it work but i also have a anti theft measure he he
i cant believe i managed it, and thanks for everyones help and advice .
i feel i have to mention the guys at webcon for supplying me with a ultra quiet and efficiant (once knew what i was doing easy to install fuel pump with filter) .
thanks for the link to webcon supplied by DC .. HE SAID  " I've all the same problems as you except mine wont even start now  im going though everything thats been said on here and also considering an electric pump and found this http://www.webcon.co.uk/Downloads/2009-Jan%20WFP502.pdf  "
A VERY GOOD AND FAIR PRICE WAS PAID, and i promised them if i was sucessfull i would tell you lot about them .. so i have
job done :)
felga
« Reply #7 on: May 09, 2010, 01:37:11 PM »
The pump works and gives plenty of fuel but still no go :/
I`ll have to check the spark, comression and ingition timing.
Is there a way to set the distributor so i can at least start the engine ?
Andy
« Reply #8 on: May 09, 2010, 03:23:01 PM »
you should static set the timing theres is a very good old thread laying around somewhere give it a search it is normally the timing that stops these from starting after so long get someone to crank the engine while you rotate the distributor you will feel where it should roughly be by the way the engine catches and once started it will be even more visable.
if its not catching still after having a play then check that you are getting a good spark as its common that the leads give up with age if you have a good spark then get a rope out and try towing it to get it running .
« Reply #9 on: May 09, 2010, 03:27:39 PM »
 I guess this is the bis it was advertised on eBay recently. The guy mentioned, he thought it had a head gasket failure. Did you check if there was any water in the oil?
 Hope you`ll get it sorted soon.
felga
« Reply #10 on: May 09, 2010, 05:42:45 PM »
Yes that`s the one,
 I took head gasket off minute ago, And I`ll now start putting it back together. I tried to start it anyway maybe the gasket is fine, but no luck. There was a channel to the heater blocked on the junction with temp sensor. I`ll take the thermostat hoses of too to make sure that everything is clear there. There was no water in oil but I found plenty of white salt like mess inside the head and around block walls.
ALso plenty of oil inside the carb plastick pan and inside oil filter.
I`ll fit new gasket today and try to start it tomorrow.
Andrew
RSPSTEVE
« Reply #11 on: May 09, 2010, 06:27:08 PM »
Good luck with it ,
Keep us posted .
Steve
felga
« Reply #12 on: May 12, 2010, 09:39:25 PM »
Great news.
I replaced head gasket , set the valve clearance to 0.15 checked compression, 8 and 8 , put new oil and coolant in, and the car started . Had a bit of a strugle with the ignition, but found what was wrong.
I`ll test the cooling system, tomorrow for faults, leaks etc.
I need new battery and i have to sort out the front NS wheel , i think the brakes are jamed, it`s very hard to push it .
I`ll post some photos later.
Andy
« Reply #13 on: May 12, 2010, 09:49:26 PM »
Good news with the gasket replacement!
If the brakes are binding there might be some brake dust behind the seal on the wheel cylinder causing it to stick.
when you have the drum off you should be able to push tyje pistons of the offending cylinder in and watch them return to their origonal position.
They can be stripped and cleaned, but I don't think they are very expensive.
God luck
