Author Topic: Headlight adjustment/alignment  (Read 1415 times)
« on: May 02, 2010, 07:00:36 PM »
Hello. Does anyone know how to adjust/align the headlamps? I replaced all the screws and plastic clips that are used to adjust and the hold the headlight in place respectively, as most were very rusty or broken and secured by plastic ties. Is there a DIY way of doing this?
Re: Headlight adjustment/alignment
« Reply #1 on: May 03, 2010, 12:42:57 PM »
drive your car up to a wall and stop at around a metre from it then you will see the beam patterns and if they align if you have adjusted or removed both lamp units then you will need to judge it as you wont have anything to go by but generally align both beams up and make them sit at the height of the vehicle or dip slightly lower this is only a rough adjustment go to a garage to get them set spot on.
