Author Topic: new model brake drums on old car  (Read 1568 times)
stefanikoss
« on: April 29, 2010, 03:01:43 PM »
does it work to take of the old model brakedrums and just replace them with the new model ones
my fiat 126 is an -75
///stefan
Re: new model brake drums on old car
« Reply #1 on: April 29, 2010, 04:05:09 PM »
The old type brake drums which are like the Fiat 500 have the wheel bearings built in . The later 126 cars have a separate hub , larger wheel bearings and a separate brake drum.
stefanikoss
« Reply #2 on: April 30, 2010, 06:06:16 AM »
but does it work if i take the whole suspension then
« Reply #3 on: May 02, 2010, 08:05:32 AM »
I have checked out a few parts this morning and the 126 hubs will not fit the smaller axle on the early cars. The early brake backing plates have a two bolt mounting to the stub axles, later ones have three. Yes you can swop the early & late stub axles along with the brakes etc. You could also fit disc brakes if you can source the parts where you are  [-/
