Author Topic: AC engine rattle/clatter  (Read 2259 times)
bath126p
« on: April 25, 2010, 03:10:00 PM »
Hi Guys
I have recently purchased a 1997 air cooled 126 EL and driven it back from Poland with no issues. However, the engine has now develop a clattering/rattling sound. It sounds metallic, like something is lose, and increases as the revs increase. It does it when stationary in neutral too.
I'm not really sure where to start looking, so anything to point me in the right direction would be most welcome. The rockers seem to be tight, and it still starts easily so I'm guessing the compression is ok.
Other than this issue I love the car, so I'm keen to get it sorted (had an Mot booked for sat but was too worried to drive the car!)
Re: AC engine rattle/clatter
« Reply #1 on: April 25, 2010, 05:51:58 PM »
If it sounds more like a rattle than a deep rumble then theres a fair chance a bit of your tinwork has rattled loose. Either that or an exhaust bracket, but thats usually accompanied with an oil leak from one of the boltholes.
I'd rule those out before getting too worried.
lilgreencar
« Reply #2 on: April 25, 2010, 06:35:45 PM »
I had a similar clattering sound recently. I spent ages trying to find it and ended up checking and tightening all the tinwork, exhaust brackets, engine mounts, etc. Mine turned out to be a loose cooling fan. I finally homed in on this when I took off the fan belt, ran the engine briefly with no alternator and fan, and there was no more clattering.
I took off the large air intake hose, reached in and did up the nut that holds the fan and that finally cured the clattering. Worth a check...
-lgc
« Last Edit: April 25, 2010, 06:37:59 PM by lilgreencar »
bath126p
« Reply #3 on: April 26, 2010, 10:25:27 AM »
Thanks for all your suggestions. I took the fan belt off last night, but to no avail - clatter is still there.
It sounds like the top end of the engine, or possibly exhaust. All the bolts are tight however. Has anyone experienced the silencer baffles coming loose etc? Or maybe problems with the cat (I'm not sure how these work on these engines!)
I'm not wanting to panic, but I am in fear of using the car as it's all a bit unknown to me.
« Reply #4 on: April 26, 2010, 10:21:27 PM »
you say the top end of the engine it is possible that the tin work has started to come loose inside at the spot welds ive had this and sounds bloody awfull! have a look under the airfilter housing section as there is a piece of metal that guides air towards the head and that can come loose.
 other than that its been already mentioned about the exhaust brackets coming loose .
bath126p
« Reply #5 on: April 27, 2010, 09:47:51 AM »
Thanks guys... will take a look after work.
My neighbours love me unbolting a Polish Fiat on the road... ha ha!
