Author Topic: Sat Nav in Fiat 500  (Read 1350 times)
Sat Nav in Fiat 500
« on: April 23, 2010, 07:51:19 PM »
When I got my car about over 2 years ago , a 72 Fiat 500L left hand drive , the only non standard thing on the car was that it had been fitted with electric screen washers. The little knackered rubber bowl pump (same as the 126) was still in place so I thought I would remove it . Got the pump out of the bracket but the bracket mounting screws are hard to get at so it remained .
Got a Tom Tom sat nav given to me for my birthday which I found quite useful in the 500 especially as the speedo in my car is in kms/hr but I had to run it on the rechargeable battery so limited life.  :oops:
Had a think about it & wondered if I could fit a cig lighter socket in the vacant bracket under the dash. So squandered £3.10 inc postage on a brand new Fiat 127 illuminated socket from eBay. It is a perfect fit  :D
Have not wired it in yet but I also do not like things that obscure the windscreen so found that I could use the suction mount on the painted section above the screen  [-/
All I need to do now is get the motor running properly  :(
