Author Topic: Front panel  (Read 1488 times)
Front panel
« on: April 19, 2010, 05:02:03 PM »
With all the rain recently I left my 126 for a week and the front end filled with water!  On closer inspection I notice that the seam of the front panel has been filled with seam sealer and the drain hole by the batt has been filled in, would it be worth removing this seam sealer and repainting or should I just drill a drain hole?
Re: Front panel
« Reply #1 on: April 19, 2010, 05:56:02 PM »
If you look at the bottom seam on the front panel you should be able to see where the drain points are. If they are blocked or covered in sealant then you need to clear them , same with the doors & the sills otherwise you are committing corrosion suicide  :o
Re: Front panel
« Reply #2 on: August 08, 2010, 09:42:20 AM »
Would you take all the seam sealent out to reveal the seam or just unblock the drain holes?
Re: Front panel
« Reply #3 on: August 08, 2010, 10:13:57 AM »
just unblock the drain holes, the rest of the gunk might be doing you a favour
