Author Topic: Leaking Coolant  (Read 2411 times)
Alex
Leaking Coolant
« on: April 19, 2010, 09:22:55 AM »
Hello Chaps!
got a bit of a strange one here, as i mentioned the other week their is a leak on the car, and as i saod it was above the radiator,
after a closer inspection it is actually leaking where you fill the coolant up, right up by the cap.
so i took the components out and cleaned them up! thinking this might solve the problem, alas it didn't and its still leaking.
also th eengine is not running properly because there is no pressure in the hoses, it gets to a certain point then starts to kangaroo as the pressure drops out!
so i have attached some photo's in the chance of maybe another member of experienced the same problem.
this is the plastic washer
this is the washer on the tube
heres the whole component.
Re: Leaking Coolant
« Reply #1 on: April 19, 2010, 07:09:55 PM »
Hi Alex,
It more than likely leaking out of the radiator cap,
When you filled it up did you fill the radiator until the light on the dash went out ???
Did you bleed the air out of the system under the front bonnet and the brass nut on top of the radiator where the top hose connects ???
Have you removed the thermostat ???
When it starts to run rough is there any water spitting out of the exhaust ???
If it is you need to do a compression test as it could be the the cylinder head gasket.
Alex
Re: Leaking Coolant
« Reply #2 on: April 23, 2010, 08:29:35 AM »
Hi pete,
coolant is filled to the top, and does not leak when engine is cold.
only starts to leak once engine is running, and is leaking out at the cap.
have bled the system and checked it regulary, no air pockets there.
occasionaly get small drops of water from exhaust, but the carb is untuned and the mixer screws all messed up
Re: Leaking Coolant
« Reply #3 on: April 23, 2010, 07:10:02 PM »
When you say filled to the top, Do you mean to the radiator cap ???
Alex
Re: Leaking Coolant
« Reply #4 on: April 25, 2010, 09:18:21 PM »
Yeah to the cap!
Alex
Re: Leaking Coolant
« Reply #5 on: April 26, 2010, 07:34:16 AM »
Its overfilled Alex, easiest way is to undo the the brass bolt on the top of the radiator just where the top hose connects and let it drain out to that level. When its stopped put it back in, turn the ignition on, the low level coolant warning light should be on, Fill the radiator up until the light goes out on the dash,
Warm the engine up, bleed the system the small pipe on top of the heater box under the front bonnet, turn off the engine leave a few minutes. If the low warning light comes on just add water till it goes out.
Alex
Re: Leaking Coolant
« Reply #6 on: April 26, 2010, 04:20:07 PM »
Really??
that was all the problem was? i tel lyou what these cars are a bloody nightmare when you dont have any literature for them.
cheers for your help Pete
i'll sort that out this weekend
 :D :D :D
Re: Leaking Coolant
« Reply #7 on: April 26, 2010, 08:22:19 PM »
Let us know how you get on, That should sort the the leaking water problem as long as there is no other underlying problem.The Radiator cap should be O.K.
As for the the Kangorooing That could be Electrical or a fault with the carb Best thing to do is replace the points and condenser first you should be able to pick them up from any motor factors for around a tenner there not a specialist part, Set the points first then check the timing, Static or with a strobe and see if that cures the problem.
Can I just remind Members that we have a Great Subscriber Section with Loads of info on the Aircooled and Watercooled Bis, that can be Downloaded or printed out, This helps to keep the Forum on line as we buy our own Bandwidth/Storage, and keeps the forum advert free. Plug Over :D
