Author Topic: Little indicator issue  (Read 2015 times)
Adamamon
« on: April 18, 2010, 06:58:15 PM »
Hmm,  my indicators are being odd.
At this second in time none of them work. But earlier they did work fine, the only issue was that with the lights on, the back left break light flashed instead of the yellow indicator light.
I looked inside and saw some weird circuit idea of a light wiring but that turned out to be normal for the Bis and I realised its actually very simple but I'm sure that's not the problem. Just a wire somewhere but any advice?
cheers
Add
The world is a piece of cake, if only you had a big enough fork.
Re: Little indicator issue
« Reply #1 on: April 18, 2010, 07:34:56 PM »
Blown fuse?
Adamamon
« Reply #2 on: April 18, 2010, 10:51:23 PM »
Good answer! Now where do I find said fuse and what do i replace with?
As in what fuse. lol
goombas
  • 126p 1992 650e
    • www.wirtualnygostyn.pl/racing
« Reply #3 on: April 19, 2010, 06:58:41 AM »
in 126 always the stronger you havei :P
« Last Edit: April 19, 2010, 07:00:19 AM by goombas »
...if good thought that frontwheeldrive is better we would ended up walking on hands...
« Reply #4 on: April 19, 2010, 08:59:54 AM »
It sounds like a bad earth.
Run a cable (jump lead will do) from the earth connector on the light to the engine earth strap, or any part of th engine block as long as its clean.
This should confirm that you earth wire is not working correctly.
goombas
  • 126p 1992 650e
« Reply #5 on: April 20, 2010, 06:52:37 AM »
i thoght so to but it was a fuse he says
