Fiat 126 Chat
Fiat 126 Chat
transmission
Pages: [
Topic: transmission (Read 1908 times)
stefanikoss
Member
transmission
on:
April 13, 2010, 07:11:59 PM »
were do i fill tranny oil
can someone help me with a picture and so on
how much oil should i fill
/Stefanikoss
Na most a tuti- tuti- tuti
Re: transmission
Reply #1 on:
April 13, 2010, 07:58:35 PM »
You'll need 1.1l of 80W-90 transmission oil. The filler plug is located on the right hand side of the gearbox next to the bell housing (between the bell housing and half axle.) If there's lots of dirt there then you'll have to clean it off to see it (square head plug , 13 spanner). Someone else probably has a picture of it....
stefanikoss
Member
Re: transmission
Reply #2 on:
April 13, 2010, 08:41:35 PM »
thanks alot mate
now i know
Subscriber VIP+
Re: transmission
Reply #3 on:
April 13, 2010, 08:49:53 PM »
If you have a short 1/2" drive socket extension , reverse it & tap it onto the square plug head then it is easy to get a spanner on the square end of the extension and makes it much easier to get a good hold on the plug [-/
stefanikoss
Member
Re: transmission
Reply #4 on:
April 14, 2010, 05:38:17 AM »
does anyone have a picture of the plug
Administrator
Re: transmission
Reply #5 on:
April 14, 2010, 10:22:02 PM »
Take the plug out and fill till the oil starts to run, then put the plug back in, you could drain all the oil out, there is a plug under the gearbox and fill the hole lot with fresh transmission oil [-/
Pete.
il cavallo piccolo
Re: transmission
Reply #6 on:
April 18, 2010, 07:46:54 PM »
Would that be a picture of a BIS gearbox?
Pages: [
Fiat 126 Chat
Fiat 126 Chat
transmission
