Author Topic: Inner Tubes  (Read 1719 times)
Inner Tubes
« on: April 13, 2010, 08:19:21 AM »
Hey
Can you fit inner tubes to the rear of a Bis as my tyre man said you can't!  Air keeps leaking out the rims of my alloys!
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
Re: Inner Tubes
« Reply #1 on: April 13, 2010, 02:54:08 PM »
I'm pretty sure it's no longer legal to fit inner tubes to tubeless wheels/tyres.
Are the wheels excessively corroded to allow air to escape? Usually when the tyre is off, all it takes is an electric drill with a sanding attachment for a couple of minutes and all is well.
Re: Inner Tubes
« Reply #2 on: April 15, 2010, 07:35:32 PM »
The alloys are repairable. I had a leak in my old minilites some years ago. If you submerge the whole wheel in water you can actually see the leak coming from the alloys. I am not sure what they did but they covered along the inside of the alloy what looked like an epoxy resin but not sure. It did not leak again.
