Author Topic: Aircooled restoration  (Read 9718 times)
« on: April 11, 2010, 11:46:42 PM »
I've had an aircooled sat in my driveway since last year which needs a bit of work doing to it.
Rotten bits:
bottom of both doors,
top of drivers wing,
rear drivers arch,
rear tail light section,
section below windscreen,
both wing repeater sections.
The plus sides are that the sills and floor are solid and the rest of the arches are remarkablely intact.
I started welding a few weeks ago. I managed to source a few panels that I was able to cut from a 126 (the donor was in much worse condition than mine, but thankfully in different areas)
I cut out the section surrounding the rear tail light and have welded in its replacement.
I think I got it pretty close, but it will still require a little filling to make it perfect. I'm trying out lead fill on this section as it is an area prone to water ingress.
I had a replacement door ready to use, but it doesn't fit!!!
It bolts in ok, but sags far too much and when shut, leaves a panel gap that is tapered, making either the car or the door look squint. I attempted every trick I knew to bring it into line, but in the end I employed the rather brutal tactic of cutting the bottom of the good door and welding into onto the original.
There is a reinforced section of the door that the hinges are welded onto. By leaving that intact, the only changes I made were to the skin, so when everything was tacked in place and offered up, it still fitted the same.
welded it together and the next step is to apply some filler to the weld line area.
For the mean time the door is sat in our spare bedroom to dry it out a bit before I give the innards a good rustproofing and apply some paint. My Girlfriend hasn't noticed that the door is in there....yet!
Door will be painted within the week to verde brilliante (colour of the inside of the door)
I already have tha paint in the garage from an ebay company who mix to code or pantone (let me know if you need their details) so it's rolling forward, slowley!
« Last Edit: April 14, 2010, 09:17:18 PM by michaelodonnell500 »
Jan-in-UK
Re: Aircooled restoration
« Reply #1 on: April 27, 2010, 09:35:36 PM »
Finaly rolling :D
www.fsoclub.co.uk
RSPSTEVE
« Reply #2 on: April 27, 2010, 10:12:38 PM »
Good luck with this , keep the pics comming please
Steve
« Reply #3 on: May 31, 2010, 06:29:29 PM »
Still haven't finished off that door yet! But I made a start on some other parts that were bothering me:
I've sprayed some BRG on there. Not it's final colour, but I'm not ready to paint it properly yet so I just needed something to keep the rain off. It will need a little lick of fill where I ground the welds back, and where I 'tapped' it a bit hard with the hammer!
I decided to make this out of three sections, Once the heat gets onto the metal things tend to move a bit, so this allowed me to adjust with each piece. The flat piece was bent by hand to fit the contours of the scuttle panel, this made it allot easier during welding and means I don't have to use much filler
As with the indicator panel I've sprayed it, but it's due some filler and sanding before it sees a proper coat
« Last Edit: May 31, 2010, 06:40:28 PM by michaelodonnell500 »
« Reply #4 on: May 31, 2010, 08:32:32 PM »
Michael well done I think I need to do this to Frasers, it looks as if may have been bodged on his.  Only thing is he wants the electric windows and shaved door handles before starting body repairs.
« Reply #5 on: June 01, 2010, 09:04:19 AM »
Superb!
« Reply #6 on: June 02, 2010, 05:13:14 PM »
Hey Michael, that is looking great so far.
Didn't realise you were such a skilled welder. So much better than it would've been sat on my drive any longer!
Good work
Jan-in-UK
« Reply #7 on: June 02, 2010, 06:41:33 PM »
If I would weld it you could easily find it as "tunning" :)
BTW: you have PM Michael.
www.fsoclub.co.uk
paul555
« Reply #8 on: June 04, 2010, 12:40:42 AM »
Hi Michael. I was repairing same places around windscreen on my Fiat and I'm just wonder if you going to drill holes for water drains or do grooves like on rear quarter glass (i think Jan have these on bottom of windscreen)??
smallcox
« Reply #9 on: June 04, 2010, 06:22:11 PM »
I wouldn't bother with drain holes as water between the rubber seal and bulkhead only spells RUST :cry: . I use a none drying windscreen sealant on both front and rear windows and hope the rust god stays away [-/
« Reply #10 on: June 05, 2010, 12:17:38 AM »
I hadn't quite decided yet,
I'm all for keeping things to spec, but the holes are a very poor afterthought!
Haven't heard of the non drying windscreen sealant, but I presume it is butyl adhesive compound, seems to be well recommended for fitting classic windscreens.I think I will have to give this a shot as it seems mad to pour rainwater through the car! The green paint will come off this weekend so I can re-paint in red oxide, most of it sits behind the seal so I can lay it on nice and thick.
Michael
« Reply #11 on: June 05, 2010, 08:50:51 PM »
Another sunny day, so out to bother the car with some tools again.
Cheers for the message Dom, I'm not that great a welder though, just had a bit of practice. The main job is the preparation - Cleaning metal, cutting patches and making sure you don't give yourself a headache later on!!
I Decided to take out the rear side windows. Much trickier than the front and rear due to the lack of expansion slots. I found a neat trick for taking them out though:
Using a screwdriver I was able to prize a load of M8 nuts under the seal, M10 would probably work better if you have any.
After doing the second window I found it was best to run along the top of the seal, then down the vertical part of the seal next to the B pillar. Then simply push the window out from the inside, dead easy!
There's probably a more sensible way of doing this, but it only took 10 minutes and didn't require any specialist tools so it worked for me!
Next was the fun part!!
The sill/rear arch section is a bit worse than I first thought. The last person to do repairs on the car did a good job, but he was a fan of fiberglass as well! I will be able to re-form the rear arch easy enough, but I think I'll have to buy another sill
I thought I'd start with the front side of the arch as it looked less traumatic than the other side!!
Part cut
Part shaped
Part welded
Should be able to get a bit more done tomorrow, hopefully!!
« Reply #12 on: June 06, 2010, 09:37:42 AM »
This is an amazing step by step, can't wait for more!
« Reply #13 on: June 06, 2010, 09:55:51 AM »
A friend gave me his old camera phone with a 5.0 Megapixel camera, which is just about as good as my own camera!
Means I've always got a camera with, so I figured I should put it to good use!!
« Reply #14 on: June 06, 2010, 12:07:57 PM »
Hi Michael, Your doing a Grand job keep the photos coming and keep up the momentum so we can all view your hard work and the rebirth of your 126.
Have you been round to Jans garage to pinch some of his green paint ;D
