Author Topic: Cleaning/polishing Cyl Head  (Read 2002 times)
ciccio
« on: April 11, 2010, 10:17:22 PM »
Hi Guys,
Am making good progress with the 650 build.
Have stripped cylinder head and have got myself a rotary multi tool to help with de carbonising/polishing cylinder head.
Can anyone recommend what i should i use to get the best results?
Many thanks in advance.
Ciccio
Alfons1972
  • sorry for my bad english...
Re: Cleaning/polishing Cyl Head
« Reply #1 on: April 12, 2010, 06:26:57 PM »
I did not clean a cylinder head yet but carburators. And for them I first use break-cleaner and then I use brass brushes. For the carbs I use soft ones, probably you can take harder brushes for the cylinder head outside-cleaning...
look at the photo: before and after polishing...  :)
« Last Edit: April 12, 2010, 06:29:08 PM by Alfons1972 »
Fiat 500 R
Fiat 500 giardiniera
« Reply #2 on: April 12, 2010, 08:57:11 PM »
If you are using a small high speed piece of kit then you want to use the heads / bits that will not erode the aluminium casting otherwise you will do more harm than good. So soft wire brushes and cloth / felt tips are your best bet  [-/
« Reply #3 on: April 12, 2010, 09:34:49 PM »
Hi Guys,
Ciccio
Are we talking Polishing or cleaning and matching the ports ???
