Author Topic: Starting problems  (Read 3867 times)
Starting problems
« on: April 11, 2010, 06:18:05 PM »
I took my 126 for a drive this morning which was great (it started the first time). In the afternoon, I went to see a friend with the car but thought of adding an oil additive (STP) which I had for some time. Managed to pour half the bottle into the car. Before leaving my friend's house to go home, I poured the other half of the additive. Got into the car and it would not start. There was no "clicking" noise, just nothing. Several attempts at starting, just nothing, again not even a "click". The only thing that was lighting up on the dash was the battery and oil symbols. The only thing that I tampered with was the oil. I checked the oil dip stick, the oil was above the max! Could this be the cause? We attempted to push start the car, and sure enough it started within a few yards, no problems. Left it running until the engine got warm, then switched the engine off and said my goodbyes. Got into the car again and it would not start again. It started quickly when push started again. Got home, parked it and switched off the engine, tried to start it - nothing again!
Could it be there is too much oil? I probably just need to reduce it. Could it be the solenoid? Any views?
Re: Starting problems
« Reply #1 on: April 11, 2010, 07:26:16 PM »
just pure coincidence that you played with the oil the same time the solenoid on the starter motor has gone check the wiring to the starter motor before you start forking out money for a new part.
« Reply #2 on: April 11, 2010, 11:11:45 PM »
Hopefully it is just a loose connection. I was thinking of the solenoid, but if my memory serves me well, if it was the solenoid, it would click but not start. At least that was what happened to my brother's car (Opel Manta) at the time. It was the absence of the "click" noise that made me suspicious that perhaps it is not the solenoid. However, quite recently, there was one occassion at the petrol station after filling it up with petrol, on starting, it would click and not start, but on the  second attempt, it started normally. I will need to take the air filter box out to get a clear view of the starter motor connections. Fingers crossed it is simply a loose connection.
« Reply #3 on: April 12, 2010, 10:06:20 AM »
Slightly O/T, but if you do end up deciding to buy a new starter, perhaps avoid ebay for a while. Since when was a recon  126 starter worth £199!?
Yet you can pick up a brand new ford fiesta one for £30!
« Reply #4 on: April 15, 2010, 07:28:31 PM »
Unfortunately, I checked the connections and all are tight, so it looks like it is the starter or the ignition that needs replacing. Does a reconditioned starter of 140 quid reasonable pricewise?
« Reply #5 on: April 15, 2010, 09:44:02 PM »
 Take the starter motor off and take it to a company who repair them. You`ll probably get it reconditioned for half the price this way. This is what most eBay sellers do. Most of the time if you buy a new one, you have to give them your old one.
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
« Reply #6 on: April 16, 2010, 09:13:56 PM »
The clicking you hear is the solenoid closing the contacts in the starter to allow the current from the battery to engage the motor. If you can hear the click then the solenoid is ok. If not, then the solenoid is not operating. Have you checked the engine earth strap? This is essentially the earth connection for the starter and if it's broken, the solenoid won't engage. Try connecting a jump lead from the engine block to a good earth on the frame and starting the car. If it works, your engine strap needs changing.
If this does not work, it is possible to test the starter with a pair of jump leads and a battery as long as you're careful. With the starter removed from the car, connect one cable from the body of the starter to the negative pole of the battery (the lug around the mounting bolt hole is flat enough for a jump cable to connect). Connect the other cable from the heavy connector on the solenoid to the positive terminal of the battery. To test the starter, use a short piece of wire to short the heavy connector on the solenoid to the small positive connector on the solenoid next to it. Be careful as they kick. The small drive pinion should be pushed outwards along the pinion and start to spin quickly. If not, it's knackered.
« Reply #7 on: April 17, 2010, 08:41:22 PM »
Hello. There is no clicking noise despite all the wire connections being tight. The earth connection is something I did not check, as it looks solid enough and is also tightly connected from the body and to the engine block. I will experiment with the jump leads and will let you know. I am now hoping it is the earth connector.
Unfortunately, I do not have workshop facilities, so I am unable to remove the starter myself.
« Reply #8 on: April 18, 2010, 04:46:39 PM »
Great news! The culprit is the earth connection. Many, many thanks Rockchevy85. I did exactly as suggested with the jump leads and it started!!!!!! The weird thing is the earth connector looks solid and you would not think there was anything wrong with it. Another odd thing is once I switched off the engine, it would start again without the help of the jump leads. I have used the car for most of the day and it started no problems at all. It is starting normally again. Is it perhaps the rust on the bolts on both ends of the earth connector just need cleaning (remove some of the rust) or something. Many, many thanks again!!!!!!!!!!!!!!!!!!!!!!!!!!!
rockchevy85
« Reply #9 on: April 19, 2010, 03:19:15 PM »
Glad to hear you are getting close to a resolution. It is certainly worth removing the earth strap and cleaning all points of contact. Personally I would use a piece of rough wet&dry to leave a bare metal finish around the bolt holes on the body and exhaust, and for the sake of a couple of quid stick a new earth strap on. I think Halfords sell them near the batteries. I took the earth strap off my Camaro once and it literally crumbled in my hand...mind you most of the car went that way.
« Reply #10 on: April 19, 2010, 05:21:18 PM »
It is interesting that Fiat chose to earth out the engine on the studs that hold on the rear engine support panel as they also fitted a plastic (insulating) buffer on the face where the panel mates with the main body shell. If you use a spring or star washer under the earth lead, give it a squirt of oil , then you will be OK  [-/
« Reply #11 on: April 19, 2010, 07:18:37 PM »
On the bis it earths through the rear offside chassis rail, I moved the earth from the exhaust mounting bracket to one of the starter motor bolts [-/
« Reply #12 on: April 19, 2010, 10:17:34 PM »
Pete 126 - Do you mean rather than connecting the earth connector to the engine block, connect it directly to the solenoid i.e. the left bolt which is used support the solenoid? The live wire is connected to the bolt on the right. Sounds like a good idea but Isn't too close to the live connection.
rockchevy85
« Reply #13 on: April 26, 2010, 01:33:06 PM »
I think what Pete means is that he moved the cable from the exhaust mounting bolt and onto one of the bellhousing bolts, which connects the starter to the engine block through the gap in the bellhousing.
So long as you have a good quality earth strap and it is connecting the engine block to the chassis via clean contacts you should be fine with the original locations. Rust is not your friend and does not conduct electricity so don't be afraid to scratch the area with a wire brush or rough sand paper until it's clean and shiny bare metal on display - you can always paint over once the cable is connected to stop rust from reforming.
« Reply #14 on: April 27, 2010, 11:38:49 PM »
I left the old earth cable as before as it looks solid, just cleaned the bolt ends. As a precaution, I installed a new earth connector to the starter motor bolts as suggested by Pete126. Many, many thanks again. It is amazing how rust can disrupt the flow of current even when the bolts were relatively tight.
