Author Topic: A Few Questions  (Read 1924 times)
Alex
A Few Questions
« on: April 08, 2010, 09:35:58 AM »
Hello All,
well the car has been running for two weeks now but has developed a few problems!
firstly, there is a leak which appears to be coming from above the radiator, anyone had experience of this?
secondly, the belt is now squeeking! not surprising since it has not run for 3 years, dont want to get one off Fleabay and pay throught the nose, do the stock them at motor factors? if so what size/code are they?
thirdly, brakes are squeeking now, this is with new drums as well, any ideas?
finally, do the windscreen wipers have an intermediate setting?
thanks in advance
Alex
bardy
Re: A Few Questions
« Reply #1 on: April 08, 2010, 10:20:01 AM »
i got my fan belt from a motor factors nd i just fiat 126 BIS fan belt nd they just asked year nd they got sum in.
RSPSTEVE
Re: A Few Questions
« Reply #2 on: April 08, 2010, 08:41:41 PM »
Mine has intermitant wipers .
horatiomcblythe
Re: A Few Questions
« Reply #3 on: April 10, 2010, 06:39:02 PM »
Mine work intermittently but i think thats more a wiring fault as its relative to the bumps in the road lol.I know it dont help you but it should get a laugh :)
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
Re: A Few Questions
« Reply #4 on: April 12, 2010, 11:22:38 PM »
You should be able to pick up a belt from a motor factor. I usually take the old one with me to match it up. When you take the old one off, run some wet & dry over the pulleys as a slipping belt can leave them shiny and the new belt won't grip too well.
Not had a leak from above the radiator, I believe the filler tube enters above the rad and there is some pipework behind the plastic grille. You might find removing the nearside rear light cluster will give you the best view of this area.
Squeaking brakes could be attributable to a buildup of brake dust, or it could be a sharp leading edge on one of the shoes.
Alex
Re: A Few Questions
« Reply #5 on: April 13, 2010, 09:29:22 AM »
cheers for the advice chaps!
brakes were build up of dust,
tightenede the belt up and its fine,
the leak is from the either the tank or the return pipe to the tank from the rad.
looks a complete B**ch to work on, but will get it done.
cheers
