Author Topic: Race/Rally Flywheels (fully Lightened)  (Read 3494 times)
« on: April 07, 2010, 07:13:17 PM »
Found these 2.7Kg Flywheels on Polish Ebay, They accept Paypal. Delivery time around 2/3 weeks [-/ For 500/126 Aircooled.
http://cgi.ebay.co.uk/Schwungrad-flywheel-fiat-126-500-2-7kg-nie-abarth-/120635965551?pt=LH_DefaultDomain_212&hash=item1c1676c06f
« Last Edit: October 24, 2010, 09:56:49 PM by Pete126 »
Re: Race/Rally Flywheels (fully Lightened)
« Reply #1 on: April 09, 2010, 10:55:04 AM »
How does it work in terms of balance fitting one of these? Are they are straight swap or would other parts need fettling?
cos124
« Reply #2 on: April 09, 2010, 11:10:14 AM »
closer to the ring gear there are 3 small holes drilled, which means that the flywheel has been balanced, but idealy it's best to get crank and flywheel sent away for balancing.
« Reply #3 on: July 07, 2010, 08:38:01 PM »
Pete, just recieved my lightened flywheel today.  I have 3 chips on the friction face, I will polish off the sharp edges.  Have you fitted yours yet, did or are you going to have the crank , flywheel, conrods and pistons balanced, do you think this will make a difference?  Now need to think about a cam now.
« Reply #4 on: July 07, 2010, 10:04:57 PM »
Hi Ralph,
No I've not fitted it yet, still getting parts together for the rebuild.
I would get the bottom end balanced it will pay you in the long run, Smoother running and less ware means more performance.
There's nothing worse than spending hours cleaning and rebuilding an engine, bolting it in and then it vibrates like hell and having to start again. unfortunately I've been there :( and i intend to get it all balanced together.
« Reply #5 on: July 08, 2010, 12:53:04 PM »
It seems awful light.  I have noticed a couple of chips/dings to the edge of the friction face, I will smooth all rough edges and hope they don't cause excesive wear to the friction plate. I will post a photo later for your opinions.
Allan
« Reply #6 on: July 08, 2010, 10:17:43 PM »
Has the clutch face been reground. It doesn't look like it to me.
Allan
« Reply #7 on: July 08, 2010, 11:13:36 PM »
I don't think so see photo
« Reply #8 on: July 09, 2010, 07:40:59 PM »
Do you think its been damaged in transit ??? I don't think it would pose a problem as long as the dents haven't left a raised spot on the contact surface.
Also remember that the clutch plate slips against the flywheel surface so will bed in naturally.
« Reply #9 on: July 10, 2010, 05:05:00 PM »
Pete no I don't think it was damaged in transit, no chips in the packagng and it was well packed, but it may have been.  I will be polishing them out along with de-burring the holes.  Hope to fit before the end of the summer.  It will go in my Gamine not Frasers 126.
