Author Topic: Swapping engine to a VW Beetle can it be done?  (Read 1574 times)
andyj_corfu
  • BIG RED
« on: April 07, 2010, 03:57:07 PM »
Hi i was wondering does anybody know of a beetle engine in a 126 bis.
Ive been trying to put original engine right, but it seems to be fighting me all of the way.
i just want it to run nice and be reliable.
any thoughts any one.
im in the lichfield Staffordshire area any help or advice would be great.
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
Re: Swapping engine to a VW Beetle can it be done?
« Reply #1 on: April 07, 2010, 05:08:14 PM »
if you do swop your eng, ill have your spare please :)
whats fighting with you on the bis eng mate?
andyj_corfu
  • BIG RED
« Reply #2 on: April 07, 2010, 05:37:52 PM »
Well, take a breath.
When i bought it the bloke said that the rear N/S brake was seized so when i picked it up the genisus put the drum brake back on,
Being new to the car fixing up thing, im usally bikes (ducati).
I didnt say any thing about 7 miles down the road after being towed with a fixed bar i noticed that there was a weird smell and a touch of smoke coming from the back we stoppped and there was a lot of somke
When i looked closer i could see small flames from the top of the drums, S+#T i said that aint good so i ran into a golf club to get a bucket of water and drench the brake,
Every thing sizzled and at closer inspection all the rubber bits and braking material was gone.
When i get it home poking and proding with a screwdriver found some holes in the body work.
One in the off side sill near the rear wheel arch,
One where there plunger switch on the drivers doors,
Between the hinges on the boot.
Where again the genius put OZ racing wheels on (because they looked good) they had rubbed the N/S wheel arch put a piont where the metal had split.
So i replaced the master cylinder,
All four brake cylinder and shoes, springs and clips.
Turned the engine on, smoke and smell, so stopped it.
Had a look there is creamy stuff in the oil filler cap,
A leak from the bottom of the rocker cover.
so i changed the head gasket, rocker cover gasket, exhaust gasket, water thing on the top of the engine gasket,
Now still its got a little leak and its started to run fast.
and i still havent seen the cooling fan turn on so im worried about that to.
I think a VW Beetle enginr would just be a better alround engine./
sorry to go on but i dont have a clue what to do.
cheers for the interest.
« Reply #3 on: April 07, 2010, 06:24:53 PM »
when you say you changed the headgasket did you check that the head is not warped and if so have it skimmed? have you removed the thermostat? the rocker covers can develop can rot and might have small perforations if in good nick then use gasket seal along with fibrous washers on the nuts over tightening can squash the rocker cover gaskets.
 as for sticking in a beetle engine then if you are struggling to get this little engine to work then i would think that the translant would be equally stressfull and this is not meant as a dig at your mechanical knowledge in any way shape or form. carry on with your work as it sounds like this car has had no work done on it for a while the bis needs care to keep it working in tip top order the brakes are notorious for seizing up due to not being used i did the same once with a car i bought and nearly came a cropper when i found i had no brakes as they exploded on the slip road to enter clacket lane services and found the only way to stop was by using the hand brake and a tastefull piece of lanscape gardening! there are some real decent bis owner/experts on here so tap what knowledge they have and you will win!!
andyj_corfu
  • BIG RED
« Reply #4 on: April 07, 2010, 08:32:46 PM »
sweet nice one,ill check out all ive learnt in the morning.
yeah ive done my fair share of landscaping in the past.
