Author Topic: does anyonne know the correct torque settings for the bis rocker cover? and mayb  (Read 1963 times)
andyj_corfu
  • BIG RED
hi ive been fixing up my newly bought bis and keep reading on hear tighten to the torque settings in the manual, what manual is this i thought haynes didnt do a bis manual.
so i need a little help in my quest to stop an oil leak from my rocker cover only a dribble but a dribble on to a hot exhaust = alot of smoke.
i have new a gasket there be it a cork one. i think i may have over tightened the nuts.
dont you hate that!!! ouch
126bis1997
I had similar problem and what I did was checked that cover where nuts seat were flat coz due to extra tightening oil may leak and even I put rubber o rings under the flat washer and spring washers before tightening everything back to plase. Hope this helps take care of your BIS
Cheers PETER.
Haynes never produced a workshop manual for the bis, although they did do a basic manual which can be found in the download area of this forum.
The manual that the forum often refers to is the factory fiat manual.
Here is an extract from the torque settings page.
andyj_corfu
  • BIG RED
cheers guys!
also i put new oil in the car and ran it for about 3 minutes then looked in the oil filler cap and there was  creamy oily stuff there.
any ideas?
kamilb1998
cheers guys!
any ideas?
Headgasket or just condensation
