Author Topic: Car running very badly  (Read 1925 times)
FiatBuggy
« on: April 07, 2010, 08:08:30 AM »
Hi Everybody,
My 126 BIS was running ok but now will only run with the choke on ! when the choke is shut off the car cuts out immediately and thats only when idling. Car wont rev up with the choke on. I have spend hours under the bonnet checking & cleaning etc. Please can anyone help. Thanks.
« Last Edit: April 09, 2010, 03:08:52 PM by FiatBuggy »
Re: Car running badly
« Reply #1 on: April 07, 2010, 06:58:12 PM »
you say that it will only RUN on choke and it will not REV? i think you might have a dodgy fuel pump.
FiatBuggy
« Reply #2 on: April 08, 2010, 07:39:35 AM »
Thanks for that but the engine is running on a gravity "drip" feed ?? Funny thing is it was running perfectly before but is now as described ! Appreciate the help.
Re: Car running very badly
« Reply #3 on: April 09, 2010, 09:10:19 PM »
A leak on the induction side somewhere.... or it may be a clogged fuel tap ???
FiatBuggy
« Reply #4 on: April 10, 2010, 10:45:42 AM »
Thanks. I will try that out. Would anyone know where i would get a reasonable carburettor for the 126BIS ?
« Reply #5 on: April 10, 2010, 11:07:43 AM »
you wont get the engine running properly using a gravity feed there is no pressure so i think you might not be able to solve the problem until you use a proper pump.
FiatBuggy
« Reply #6 on: April 13, 2010, 07:51:36 AM »
I had it running on a drip perfectly. i just cant figure out what changed. would it possible be a timing problem?
« Reply #7 on: April 13, 2010, 08:25:14 AM »
Timing?
